Results 1 to 3 of 3
Thread: e67 comp, no PE above 2,600 rpm
    Oct 2019
    lakewood wa
    born before the computer age, 2012 Colorado 5.3 with a 1900 supercharger, it has the tune supplied by the manufacturer, VCM scanner shows PE about 1,200 rpm to 2,600rpm then gone, running 14.68, 1 bar MAP, I'm towing a travel trailer, also my throttle position sensor reads 83.9% at full throttle, pedal signal says 100%, and I know TPS should read 88% at full throttle, Is this a dumb question??? i'm lost, just bought a wide band, won't be here for 10 days, need help, UPDATE--- have hp's scanner on 2 computers, the 1 im tuning with was outdated, so i updated it, got my wide band in and guess what--- wide band says I have PE, the scanner says I have PE now, and other stuff works in the scanner works now, woopi, even the tps reads 99.6, could my scanner have been corrupted some how ?????
    Nov 2009
    All Around
    3,149
    post the tune
    13,585
    May need to lower the map enable from 100kpa down to 90kpa instead.
    I hope the transmission is up to snuff too, that tune is pretty aggressive for a stock 4L60e.
