Results 1 to 20 of 21
Thread: JTEC scanner set up
    Nov 2008
    Tampico Bay, Mexico
    220
    JTEC scanner set up
    just begin working on this new plataform and the first doubt comes .... how to set up VE error on this PCMs I can only see map in Volts and not in pressure (Kpa or PSi) any guidence will be great
    also i cant log spark advance or retard im lost on this new aplications
    BTW im working on a cammed and ported 1998 4.0 auto jeep wrangler
    i have it iddling and running just by adjusting based on the wideband reading but i cant make a correct adjust until i can log VE error the right way so lets see if anyone have a clue on this 1998 wrangler 40A3 silva stk.hpt1998 wrangler 40A3 silva base6.hpt
    all the way from Tampico bay Mexico
    823
    I've seen 2 files so far from a JTEC - this one and the sample posted in the thread above.
    Neither has VE tables that I can find, just direct pulse width and a strange PE table that doesn't make sense to me.
    Is there a commanded EQ, AFR or FAR channel?
    May 2006
    19
    JTEC does not use VE tables, the only thing you can do is log O2 correction and make changes to pulsewidth to get the fuel within 5%
    823
    That's what I was going to suggest. Log lambda and use current lambda over expected lambda as a multiplier on the pulse width table in the area you are working with.
    May 2005
    Los Angeles
    161
    The part throttle enrichment and wot enrichment are fuel air multipliers, on some JTECs there are delays for entering PE but most earlier JTEC cals have those zeroed out.
    You can use the part throttle and wot enrichment as you target lambda , make an excel spreadsheet, apply your logged lambda against your target lambda then use that multiplier to modify your pulsewidth fuel table.
    Nov 2008
    Tampico Bay, Mexico
    220
    yes but how i log the error if i cant plot speed density (rpm * pressure) ? cause i cant log MAP?
    823
    Quote Originally Posted by dlc_racing View Post
    You don't need to.
    The error is what you see on the gauge divided by what you want it to be.
    823
    This is actually much more simple than what you're thinking it is.....
    Nov 2008
    Tampico Bay, Mexico
    220
    ok i log lambda vs expected lambda (commanded vs requested) but wath will be the other axis? map volts?? so i can know were to adjust the pulsewith table ..sorry but my head is hurting to get a grip on this new format ..too much VE from GM and maf from ford
    May 2006
    19
    the 2 axis should be rpms/MAP kpa I would think. You want to log the same factors of the base fuel table which is MAP kpa(torr) and RPM.
    Nov 2008
    Tampico Bay, Mexico
    220
    sorry but the early jtec dont log map in pressure only in volts (1998 wrangler pcm) but the 2000 cherokee does so thanks for your help
    823
    Send a request in to support. Also, you could make your own custom math to convert it if you know the correct scaling for the map sensor.
    Oct 2019
    20
    I?m having same problems with logging my 98 xj. I?ve sent a case and they are definitely working on it. Can someone steer me in the correct detection on what?s base spark egr on and off. These engines don?t have egr I?m just assuming it?s labeled wrong.
    823
    Did either of you try to create a math channel in the mean time?
    Should be pretty easy to figure out V x X = kpa. And if the map cannot be rescaled above 105 for boost (which it seems like) making a math channel might be the best way to tackle this even if kpa is available.
    Oct 2019
    20
    I?m not currently in boost, but I?ll will to know this too. I?ve got a whole setup, just haven?t had time to finish it. But I do have a stroker 4.7 big cam, and lots of port work. She?s currently totally flat over
    4200rpm. I can?t log so I can?t adjust much yet.
    Apr 2014
    706
    The equation is y=mx+b, where y is the map value, m is the slope, x is the voltage input, and b is the offset.
    To find the slope, you need to know 2 points of data (usually advertised at 0.5 volts and 4.5 volts - min and max).
    Just as an example of how to solve for "m" and "b", here are some arbitrary numbers:
    Say a 2 bar map sensor minimum output of 0.5 volts occurs at 20 kPa, and max output of 4.5 occurs at 200 kPa.
    (200 - 20) / (4.5 - 0.5) = 45
    45 is your slope (m)
    Now, using the slope, multiply it by either the min or max voltage to see what it outputs:
    45 * 0.5 = 22.5
    or
    45 * 4.5 = 202.5
    In either case, the offset to reach the advertised output at the corresponding voltage is -2.5
    20 - 22.5 = -2.5
    or
    200 - 202.5 = -2.5
    So, the math parameter for this sensor would be:
    y = 45 * x + (-2.5), and x would be your map voltage pid.
    823
    Advanced Tuner axekick's Avatar
    Aug 2009
    Austin, TX
    333
    They've gotten the scanner to log MAP and ECT succesfully with the latest Beta but instead of Fuel trims there are fuel multipliers and they don't seem to work the same, at least not on my Jeep. Also, the only time I tried to run in open loop, there were still big values in the LTFMs and I'm not sure that there's a way to clear them. Maybe the old disconnect the battery and discharge capacitors trick might work.
    2006 Tahoe
    Iron ls2, built up 4l60e w/vig 3000 stall, 232/234 114, 4.30s, LTs, ORY NNBS intake and LS2 TB etc.
    Fighting solves everything...
    ...except partial differential equations.
    Click here to combine multiple VE Logs into one.
    Oct 2019
    20
    Dlc_racing hows she running so far? I was comparing our stock files, look pretty similar; small changes probably because I?ve got a auto. How?s she running with your adjustments. I don?t have my wideband setup yet so I can?t really do anything. I?m currently having some huge dead spots over 4200
    Jan 2010
    16
    a mi no me da ningun dato el escaner con las jtec o jtec+
    hola, crees que me podr?as ayudar? tengo 4 dias tratando de hacer log en un ram 2000, pero por mas que lo intento cuando me conecto con el scaner no me jala ningun dato, RPM, MAP, TPS, AVANCE, O2S, nada de nada. yo esstoy es sonora mexico este es mi cel, 6371130216 y me email [email protected]. o pasame tu informacion y te contacto.
    muchas gracias.
