Results 1 to 5 of 5
Thread: Logging inferred/virtual fuel composition ??
    Potential Tuner Speey_Mikey's Avatar
    Akron, OH
    4
    I'm noticing in my logs the spark advance is always 5-12* higher than what the high octane table says it should be. My hunch is the computer is assuming ethanol content in the fuel and adding timing, but I want to know for sure. Is there a PID that tracks inferred/virtual fuel composition? What else could I look to know why timing is being added? I'm seeing some KR when the timing advances too far and I want to adjust whatever modifier is adding the timing. (2011 Silverado E38)
    Yes, my username is an unfortunate typo... Just call me 'Fat-Fingers'.
    2011 Silverado LT - Edgar
    2014 Grand Cherokee EcoDiesel - DJ
    2018 Camaro SS 1LE - Nicole
    13,582
    There are several spark correction tables that can add or remove timing. Anything from IAT temps to coolant temps and even the commanded EQ ratio in the calibration. If you have VVT that could also be doing something.
    All of those things can be logged. You can log ethanol/alcohol content. Same with all those spark correction tables, that way it can show what it adding or removing timing.
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Log everything with the word "advance" or "retard" in the list of available channels and you'll find out what's doing it pretty quickly. Could be PE/COT modifier, could be IAT, ECT, all kinds of stuff.. might be Ethanol content. There's an easy way to find out though.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Akron, OH
    4
    Thanks for the advice. I know there are lots of things can impact timing. Looking at the common ones and their multipliers though, I can't make them add up to 12* like I'm seeing at times. Looking for any 'advance' or 'retard' PIDs to logis a great idea. I forget how versatile VCM can be.
    What is the PID to log the virtual ethanol content? The only ones I can find show 4.3% no matter what fuel I put in it. Even with a full tank of e85, it doesn't change.
    13,582
    There isn't a special channel to log for alcohol content. I usually log both channels for ethanol/alcohol content.
    The virtual sensors are known to not work right even if the setting is set to enabled in the tune.
