This is the second time it has happened. The first time i cancelled a write during the first process of writing to the ecm to make a change before uploading the tune. After that i could no longer write or read the ecm. I took it to the dealer and the reprogrammed it with their tools and i was ok. HPT's response was "you should not abort a write" , well maybe that shouldnt be an option then.
Today my laptop powered down when i began to write a tune and same thing. Im taking it to the dealer tmr and hopefully the ecm can br saved.
When this happened today i did not reset the ignition, kept the car on and rebooted and tried to write then read and nothing. Tried unplugging the ecu, disconnecting battery and touching both terminals together while unplugged from the terminals of course, nothing worked.
This leads to my question, why cant the software force write/recover like the chevy and ford? Something as simple as moving the usb cable can completely ruin someones day. How can this be fixed?
