Results 1 to 12 of 12
Thread: Pistons carbon buid up : tuning too rich at WOT ?
    Guys,
    I'm in the process of installing my cam (TSP Stage 3).
    After removing the heads I found my pistons with significant carbon build up on them...I use my car mainly on roadcourse, hard mountain driving and AutoX. I previously had Headers, intake, Msd intake mani, ported TB and a tune I did myself (road and dyno). Car has 9300 miles.
    I was running a lambda between 0.86 (mid low rpm) to 0.84 (high rpm) because I found on the dyno it made more power this way.
    Looking at my pistons what do you think ? Should I run 0.88 as target after my cam is installed ?
    Or is it normal on the LT1 ??
    Which method will you recommed to clean that up ?
    Aug 2009
    Calibrating
    3,373
    If you are boosted that’s about right!! NA that’s too rich from what I have found makes the best power
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    13,565
    Switch to E85, it'll clean that stuff right up lol.
    Tuning Addict
    Jan 2015
    6,815
    What did the backside of the valves look like? Something seen quite often was guide clearance issues causing oil burn - top of the one piston looks like oil buildup instead of carbon from fuel....
    ~Greg Huggins~
    Not too bad for what I see. Some build up, but fairly small. Should put an oil catch can though..I'll know more when I remove the valves to do the springs swap/valve guides etc..
    Dec 2015
    Miami,Fl.
    290
    I'd install a catch can and lean it out a bit to .87/.88
    2023 Ford Maverick 2.0T AWD
    May 2007
    489
    What vehicle is this from? carbon fouling or "coking" as they call it is normal on the newer DI GM vehicles.
    Aug 2006
    Arizona
    244
    Looks normal. A catch can would help a lot. So will switching to Ethanol. Also, you should be able to run .88 lambda without an issue
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
    May 2006
    Waterbury CT.
    293
    Quote Originally Posted by Sachs View Post
    Guys,
    Which method will you recommend to clean that up ?
    I think your right on point, all my dyno tuning agrees with your findings, best torque and horsepower at .86.
    I think a catch can is the more likely fix.
    Ted.
    311
    My L86 with 120K was not tuned as far as I know it except I put a E85 sensor on it and enabled it with HP tuner about 5,000 miles before this picture. I bought it with 105K. It hurt lifter so I swap out the cam to a TSP stage two 218/225. It looked similar to yours.
    I can?t get my phone to post the picture, I post it from my work computer tomorrow
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    I think a better question is how do you drive it. In my experience pistons that look like that tend to be from people who drive moderately, and only occasionally bury their foot in the throttle. If you drive it like you stole it, they rarely look like that, even waaaay over fueled, they will be black but rarely have build up like that
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    311
    Here is my L86. I have no idea how it was driven before me.
    But
    look at MPG averages on the dash which where 4 mpg better than I get. They drove it with a much lighter foot than me LOL. And it was in perfect shape.
