Results 1 to 12 of 12
Thread: 6L80E fast learn not enabled
    Jul 2020
    17
    Hi hope someone can help here.
    I just did a 2018 L83 swap in a Land Rover defender with a 2017 6L80E
    I was trying to do a fast learn - however I don?t get the tabs for fast learn only the resets tabs
    I have 3 tabs
    Trans adapt reset
    Trans adapt preset
    Trans fast adapt reset
    Also in the PIDs
    The trans cleaning status and trans fast learn status are both disabled
    Thank for any feedback.
    Bal
    13,604
    Was the 2017 TCM programed to the 2018 file that you are using to run the engine?
    The PCM and TCM should be programmed to matching operating system.
    Jul 2020
    17
    Thank for the feed back.
    How can I program the TCM to 2018 using HP Tunners?
    I thought it was a matter of doing the fast relearn.
    13,604
    Are you even able to read the TCM off of that transmission?
    If it was me I would have flashed the PCM/TCM with a dealership GM Tool so that everything matched, then licensed the file for tuning.
    Jul 2020
    17
    I’m able to read the TCM - I looked at couple of tunes of the same year from the repository - It seems the TCM OS needs up to same year.
    Jul 2020
    17
    It seems if I want to reflash the TCM with a stock Repository tune of same year as my ECM using hp tunners I need to pay another 4 credits.
    I made the mistake at the start when I should have re-flashed both TCM and ECM with stock tune of the ECM. Oh well.
    Jul 2020
    17
    Hi hoping someone can help. The TCM OS is matching the ECM.
    I can both - however I still have the issue of Trans fast learn disable and trans cleaning status disabled.
    Jun 2020
    Mo i Rana
    Hi, I am sorry, can`t help, but I have exact same issue. Tried today with Autel maxis and got failed even doing trying the presets. Transmission is matched to ECM, (2017 L83 and 2013 6L90) Transmission is rebuilt and shifts is slipping from 2-3 and 3-4.
    Dec 2006
    Birmingham, Alabama
    156
    You may need to stop recording then try the trans reset parameters.
    Jul 2020
    17
    ill try this and see what happens
    Jun 2020
    Mo i Rana
    I never got to do a fast learn, so I just drove it "grandma" style for a while, approx 80-100miles. It shifts way better now, slipping and flare is almost gone.
    Jul 2020
    17
    Quote Originally Posted by scooby View Post
    Yeah - I’ve been told to run it for about 200km and see how that feels. Just finishing off couple of final touches and then I’ll run it for few hundred km and see.
