Results 1 to 3 of 3
Thread: Anyway to capture log file if VCM Scanner stops responding?
    Anyway to capture log file if VCM Scanner stops responding? I have a 1 hour log session and VCM Scanner froze. Would it be possible this log is a temp file somewhere that I could retrieve?
    Sep 2002
    Chicago, IL
    6,395
    VCM Scanner doesn't use temp files to buffer active logs. It's all in memory.
    Because of that, if VCM Scanner froze during the log, that log is lost.
    However, VCM Scanner does auto-save logs when you stop a session, even if you don't save them yourself. Those are stored in "\Documents\HP Tuners\VCM Scanner\Logs"
    We got this guy Not Sure, ...
    thanks keith, that information was helpful
