I like mine enabled. 1st gear goes by 2 quick. Would rather it change than hit a limiter.
Sorry to hijack your thread but I did hit the initialize egs53 button yesterday on mine. Now will hit limp mode very easily. Can hpt be used to write the file back to the mtcm or do I have to send out to be reflashed?
07 Dodge Plum Crazy Daytona
Supercharged 5.7
1/4 mile time 10.843 @ 125mph
Thanks I think I was able to fix the issue. after reading the tcm file again and comparing with my backup. Shift points were back to 5600 and rear gear was set back to 2.82, no wonder the limp mode. I rewrote the tcm file and so far so good.
Supercharged 5.7
Looks like you have a 6.1L SRT Mopar TCM (P5155177), the Operating System is P5155179AA.
I compared with my 5.7L Mopar TCM (P5153332) and there looks to be some shift scheduling differences.
Can you confirm if this is the stock MTCM file or if you have modified anything yourself?
2007 300C 5.7L - Edelbrock Eforce (7psi), Comp Cam 268H,
Mopar Ported Heads, 3.06 LSD Swap, 06 Coil Swap
465hp @ 6200 rpm / 463 ft-lb @ 4700 rpm
