gears inverted?! strange Transmission problem
hi guys, i have a firebird here which is bothering me to hell.
it's a LS3 Swap Gen3 P01 PCM, fueling, ignition, idle, more or less all fine so far.
now it comes to transmission, it's a 4L80E swap, was done by another shop, i just have to clean the mess up.
when i drive it on the dyno carefully it does 1-2 shift where i command it in the table...but overall felt strange, then it commands 2-3 shift and i first thought it unlocks the converter because rpm was going up and car was decelerating.
now it tried commanding gears manually with the scanner and came to following conclusion:
if i command 4-3-2-1 the car shifts like it should, so it is inverted somehow.
so what is wrong here?! did they wire up something wrong?
hopefully someone can help or had a similar problem before.
thanks
[edit] meanwhile I obviosly found the problem, I found the Solenoid shift order for "1-2 Solenoid" and "2-3Solenoid" for 4L80 and 4L60... and they are different.
the logic of "2-3" solenoid is exactly inverted, which lead to the behavior descibed above. i also have drawn a "shift table" to make sure that this assumption is correct, no other combination leads to this behaviour.
so my question now is: can this be fixed in software?! otherwise i have to build a little relay circuit to invert the PCMs output of "2-3Solenoid" Signal.
but hell i am sure this is not the only car which is converted from 4l60 to 4l80....are there different versions of the transmission with different logics?
[edit2] NAILED IT! had to put transmission choice in the file back to 4L60... this inverted the PCMs output logic.
