Results 1 to 12 of 12
Thread: e40 PCM not Logging boost
    Sep 2017
    5
    I have a 2005 GTO with Twin turbos running 6psi, my scanner will not read above 105 kpa.
    I have tried to delete all the PIDs and add a 2 bar channel but it never pops up with the option.
    Any ideas of what i could be doing wrong?
    13,588
    Do you have a 2 bar MAP sensor?
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    Are the e40's like the ls1 ecms, and have to log with 2 bar config?
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Sep 2017
    5
    Yes, I am running the Cobalt ss 2.5 bar MAP sensor
    Sep 2017
    5
    Quote Originally Posted by mbray01 View Post
    Mine came with my LS2 GTO, from what I have read they are sort of a mix of the Gen 3 and 4 PCMs.
    Part of the problem is i cant get the 2 bar config to pop up in my channels to log it
    Waldorf MD
    774
    Quote Originally Posted by flothepro View Post
    Are you running a 2 bar OS?
    Daily Driver= 2003 BMW 330xi
    Sep 2017
    5
    Quote Originally Posted by jaydubb71 View Post
    Yes, i followed up with all the correct steps, even tried re-writing entire. The OS code (1250150) even pops up in the scanner recognizing that the 2 Bar OS is in the PCM
    Waldorf MD
    774
    Post tune and log.
    28,288
    No they are not, they were the first of the 4th gen ecm's and use the oem map pid similar to E38 ecm's. Most likely he is not running a 2 bar or 2.5 bar sensor(this is the most common reason at least).
    Sep 2017
    5
    I am running a 2.5 bar from the cobalt ss i believe. GM code 12615136
    Dec 2013
    Slidell, La.
    1,015
    So first off, its not a 2.5, its a 2 bar, so if your settings reflect a 2.5, that part of the issue. Now secondly, where did the sensor come from? Did you buy it from a gm dealer, or from some place like rock auto, which is notorious for selling counterfeit chinese knock offs.
    Michael Bray
    Slidell, Louisiana
    20yr Master Tech.
    Shop Owner
    7,850
    Just a minor quibble... Rock Auto does not sell fake parts in AC Delco/Delphi packaging at AC Delco/Delphi prices. But if someone is stupid enough to think that a $8 'ULTRA-POWER' sensor is equivalent to a $50 AC Delco sensor, Rock Auto will let the stupid person buy the fake Chinese $8 sensor if that's what they really want.
