Page 1 of 4 1234 LastLast
Results 1 to 20 of 79
Thread: Ford Diesel Logging Update
    Oct 2007
    Crawfordville, FL
    2,415
    A lot of you guys have requested more loggable parameters to help navigate where to make changes when tuning the 2017+ Ford 6.7 diesel, and the Ford Ranger (SID-209).
    In the latest beta, I have added a few new channels for logging that will pinpoint which maps are in use.
    Parameter 14590 - Base Operating Mode will tell you which of the Map # is in use.
    Parameter 14589 - Injection Config for EOM will tell you which Config # is in use.
    Parameter 14588 - Engine Operating Mode (EOM) will tell you which Mode # is in use.
    Hope this helps.
    Eric Brooks
    HP Tuners, LLC
    Oct 2007
    Crawfordville, FL
    2,415
    In the coming days, I will add the above to the 2011-2016 6.7 as well as the 3.0L F-150 diesel.
    Eric Brooks
    HP Tuners, LLC
    Jun 2018
    Albuquerque New Mexico
    467
    Awesome i've been waiting for this, ill test it tonight. It would also be nice to get the tables added that choose which MAP# we are using based on engine temp vs some temp??? Maybe intake air? Either way we appreciate your work Eric. Map Select Via temp.PNG
    Oct 2007
    Crawfordville, FL
    2,415
    Create a support ticket, and I can get it added.
    Eric Brooks
    HP Tuners, LLC
    Quote Originally Posted by Eric@HPTuners View Post
    Is e clutch pressure also going to be added? We have a-d
    Jun 2018
    467
    Here is a log of the base mode. Not sure it's functioning right. Base OM.hplbase om.PNG
    Quote Originally Posted by JaegerWrenching View Post
    Looks like it's off by some sort of conversion factor. That number happens to be 2^16-2^10.
    Jun 2018
    467
    Quote Originally Posted by CKrueg View Post
    The one thing that gets me is i think it should move progressively lower from startup considering the maps to select this number are laid out by a temp. I don't know why it would jump up unless there are other factors at play here.
    Looks like EOM and config were working, but base map is all over the place looking at the log
    Jan 2019
    24
    Thanks Eric this will help a lot saves trying to line up logs with every chart to guess. I to would love to know what map and config is in use. Appreciate your work.
    Oct 2007
    Crawfordville, FL
    2,415
    Yeah, I forgot to scale it. It has been fixed.
    Eric Brooks
    HP Tuners, LLC
    Jan 2019
    24
    Eric has this been added for 11-16 6.7 yet? I am using VCM Scanner 4.7.247 Beta but have been unable to find it.
    Oct 2007
    Crawfordville, FL
    2,415
    Quote Originally Posted by Wrangas87 View Post
    Some, but not all OS have it.
    Eric Brooks
    HP Tuners, LLC
    Jan 2019
    24
    I updated the VCM to 4.7.277 BETA but no luck my OS is DDBM3EZ. Thanks.
    Any chance on the 2008-2010 6.4L's also?
    Thanks Rick
    Australia
    119
    ... and the Ford Ranger (SID-209).
    ___Parameter 14590 - Base Operating Mode will tell you which of the Map # is in use.
    ___Parameter 14589 - Injection Config for EOM will tell you which Config # is in use.
    ___Parameter 14588 - Engine Operating Mode (EOM) will tell you which Mode # is in use.
    The Ranger only has PRM14588 in beta 4.7.505. Has there been an issue?.
    (SID209, OS: EB3G-14C204-EFL)
    Ian B
    '15 Holden VF SSVR L77(gone), '19 Ford Ranger PX3 3.2TD, '22 Toyota GDJ150
    Oct 2015
    19
    Quote Originally Posted by VFL77 View Post
    im not even getting 14588. using the latest beta. carnt remember what version but its later than 4.7.505
    Australia
    119
    Quote Originally Posted by h41ry View Post
    I've had success with all versions from 4.7.318.
    I do find that the available parameters reported does change if you're not connected to the vehicle. Consequently, I always connect to the car and then re-poll parameters (under Vehicle heading). Also the parameter 'hides' under Engine-Fuel-Diesel-Quantity.
    I have a case logged about the other 2 missing parameters.
    Ian B
    Oct 2015
    19
    thanks i will check it again when i get a chance. looks like you have a few more pids than i do also maybe i am doing something wrong lol
    Oct 2015
    19
    any updates on this? last i checked 14590 and 14589 still was not working for the ranger sid 209
