Results 1 to 7 of 7
Thread: Editor double writing?
    Jan 2019
    24
    I don't know if it's just me or is anyone else finding on the 6.7 that it takes 4 odd minutes to write erases and writes again for nearly 3 minutes? Also I need to be online now where as before I could write even when out of range.
    Jun 2018
    Albuquerque New Mexico
    481
    It writes the ECM first and then the TCM as they are two separate controllers. Depending on how many changes you make and if you select "write entire" or "write calibration" will affect this time. Just hit write calibration which is default for the ECM to save some time, and the TCM has to write entire which doesn't take that long.
    Jan 2019
    24
    No this is when only writing the engine and not the gearbox. S am I the only one then.......hahaha
    Quote Originally Posted by Wrangas87 View Post
    I never have this on my 6.7. my only option is write entire also. Engine takes about 8 minutes and trans takes 3.
    Jan 2019
    24
    You can select from the drop downs and only write engine or gearbox. In the past it has always been about 3 minutes for engine alone and about the same for gearbox alone. I have only noticed recently tho that I have now needed internet connection to write the tunes and that for some reason when writing the engine it erases, writes for 4-5 minutes then erases again then writes again for 3 mins then gives me the 3 second turn off/on before saying complete. Maybe it's just me......
    Jun 2014
    Boise, ID
    68
    It started doing this when Write Entire became an option on the 11-12 trucks. The internet is required so that you can write these trucks. The double write happens when doing entire or cal only.
    Jan 2019
    24
    Yeah I noticed that internet was required which is really bad as I'm often a long way from reception in outback Australia. I wonder why we now need an internet connection to write tunes.
