Thread: Higher then 86% throttle? How are you guys doing it?
    Jun 2018
    609
    I was always taught that if you have your throttle in the mid 80s and consistent you're good to go. I recently ran into some scans from some other tuners and they were getting 99% throttle. Am I missing something? Is there benefits to this?
    May 2003
    South FL
    1,381
    You need to monitor the non generic PID for throttle position for it to be accurate.
    [email protected]
    Owner/GM Calibrator
    Jun 2018
    609
    So it's just a scanner set up thing. I thought that might be the issue. I think whatever this guy was using was bogus anyway. The car was clearly pulling throttle but still showed 99%.
    May 2003
    South FL
    1,381
    Yes, you can tell by the little blue arrows on the left in the PID list when the scanner is active. Two arrows is generic, one arrow is specific to the ECU. You have to click the "no, I know what I am doing" when selecting the highlighted PID in my pictures below. You can see on this scan that I am monitoring both PID's and the Generic SAE channel is incorrect.
    [email protected]
    Owner/GM Calibrator
