Results 1 to 2 of 2
Thread: Looking for direction on how to set up an Auto Up Shift on the trans calibration.
    What im looking for is the scenario (8speed and 10 speeds) where im in drive I downshift with the paddles to a low gear ( 2nd or 3rd) go wot and once I hit the correct rpm and mph the trans will shift on its own to the next gear.
    I been struggling trying all sort of combinations but I cant get the transmission to do what I want.
    Can someone please explain what is needed to get this set up and working? 2018 Camaro.hpt
    Could someone also explain what pattern A and pattern B entail?
    Aug 2009
    Calibrating
    3,414
    Very easy.. there set to high in factory form... just adjust tap shift correctly to model where you want it to shift
