To take advantage of the 01-02 VE table has anyone seen any problems completely rewriting a 99PCM with 02 or 01 OS?
i'd like to know this one as well, i'm sick of half resolution tables.
Nope no problems i took my 00 and converted it to a 01
what was your process exactly? did you flash it with stock 01, and then copied over all the values you deemed important, or did you actually tune from scratch? did you do the 'write whole pcm' option, or just a regular flash?
Originally Posted by redhardsupra
I re-wrote the entire pcm. Yes I flashed with a stock 01 and copied all of my tables from the 00 to the new bin. Write whole PCM
