Results 1 to 2 of 2
Thread: Completley different animal on restarts.
    Sep 2017
    769
    PO1 pcm. Im constantly changing stuff, flashing tunes.
    Car runs great after a flash. No issues etc.
    When say i go and stop and get gas then restart its a different car.
    It will run richer, rpms hang, coming to idle hangs as well, like there is to much throttle cracker?
    Is there a way around this. Am I just collecting data and changing things to soon without enough drive time in between changes.
    Typically id load a tune. Go out for a 15-30 min drive.
    Come home review the data and come back the next day or a few days away. Then at it again.
    I also notice this starts to happen when my coolant and IAT temps rise but seems to still happen when the IATs come down. Its somthing about the restart.
    Car at the moment is MAF/Open Loop.
    Sig has mods
    1997 30th SS. Torqhead 24x, TFS heads, 223/235 cam, 4l80e, S60 D1SC 14psi
    Tuner awest623's Avatar
    Oct 2019
    Pyeongtaek, South Korea
    70
    Tune file and a log?
    1998 GMC K1500 Z71
    * L31 350 Vortec
    * AUS 43lb injectors
    * Comp 08-410-8 with 1.6 rockers
    * P59 swap
    * Whipple supercharger
    * JBA headers
    * AFR 190cc heads
    * NV4500 swapped
    * Cal-Trac traction bars
    * 1" blocks, 265/70r17 BF Goodrich KO2s, 17X8.5 ALPHAEQUIPT COMMAND LT
