Results 1 to 7 of 7
Thread: Barometer rise under boost
    Tuner JnJSpdShop's Avatar
    Aug 2005
    Western New York
    195
    I was wondering if there is something I am missing. The car is a 2015 Corvette LT1 with an A&A supercharger kit. The car has methanol and the IAT and BARO sensor are both broken out with the DSX harness. The ZR1 MAP sensor went into the intake and the stock MAP went on the harness and is zip tied underneath the intake manifold. The dyno pull starts at 98.5 kpa and ends at 108 kpa. What am I missing??
    Western New York's Performance Headquarters
    716.830.0506
    Jun 2007
    Close to my Z06
    271
    Would be nice to get an answer
    Aug 2010
    Detroit, MI
    941
    Probably wrong pressure sensor configuration. Hard to say without the file..
    Apr 2014
    North Dakota
    64
    Try disabling the P0101 test and maxing out the Barometric Pressure Sensor (P2227) values found under Engine Diag > Airflow.
    My setup is different, using a dedicated BARO sensor, but these tests seemed to make adjustments to the BARO reading instead of just being Pass/Fail tests. Disabling them made my BARO sensor reading stable.
    2014 Silverado L83 | Knockoff S369 Turbo | LT1 Fuel Pump and Injectors | MAST L84 Port Intake | MS3Pro Secondary Fuel Computer
    So how do we measure the correct boost? Take everything from 101kpa, 98kpa, or 108kpa to find the correct boost pressure.
    So WOT 143KPA = 6.1psi
    Aug 2014
    Central, LA
    737
    Need to set sensor config to "NA-MAP"
    Advanced Tuner Ghostnotes's Avatar
    Feb 2012
    Houston, TX
    471
    Quote Originally Posted by sevinn View Post
    Hmmmmm
    I've left mine as is since I put my A&A on 2 years ago. I'm using a breakout cable but now my baro is stable now.
    I always tune VVE....
    2016 C7 M7 Z51
    Callies ultra billet crank
    Callies ultra billet rods
    Diamond pistons
    Jhonson high speed lifters
    Ported and polished headwork
    Custom cam
    YSi-V7
