Results 1 to 20 of 27
Thread: Tundra Tuning Reference
    Been working on this off-and-on while; still not complete, but with more and more people tuning Tundras I wanted to share it now that it's in a workable form. There are quite a few updates and revisions already in the pipeline (lots more for spark, adding a transmission section, and a channel listing and example polling intervals in the VCM Scanner section). I'll also add some more of tools for calculating/scaling tables in the near future (the attached tools have updates coming, too), along with some actual instructions for using them.
    This is more a quick start for those with some experience tuning to get up to speed on some idiosyncrasies, not so much a manual for someone totally new to tuning.
    PM me any corrections and errata and I'll update accordingly - feedback and suggestions are always welcome. As always, caveat emptor.
    Tundra Tuning Reference: https://drive.google.com/file/d/1vjg...7USHoswg7/view
    Ignition Efficiency Inverse Tool: Tundra Ignition Efficiency (2).xlsx
    Trans Quick Reference Tool: AB60.xlsx
    1/26/2021 - Revisions and corrections to the following:
    Updated the ignition efficiency tool to make working between the Ignition Efficiency and Inverse tables easier. I've had a few requests for this as people work around torque management tables not being available in certain calibrations.
    The past copy of the TPS tool has been removed - a revised tool to build TPS curves based on power requests will be added for distribution once a guide can be written.
    Last edited by SlowNStock; 04-26-2022 at 11:39 PM. Reason: Updated Reference to V1.1
    May 2019
    46
    How to open those document?
    Sep 2018
    34
    Thanks a lot @SlownNstock ��
    Advanced Tuner WS6HUMMER's Avatar
    Feb 2006
    Pineville La. US
    771
    This is awesome, thank you for doing this!
    Feb 2006
    Pineville La. US
    771
    If calibrating the speedometer in the software will solve the speed mismatch issue but not make the speedometer read accurately is there another way to actually correct the speedometer?
    The slides you made are so helpful, thanks again!
    99 T/A WS6, original LS1 turbo
    Quote Originally Posted by WS6HUMMER View Post
    Happy to share, it's better for everyone if information is easy to have. If you find anything confusing or needing clarification or just plain incorrect (other than the spark section, I'm actively working on a big revision for that), let me know and I'll get it updated.
    Correcting the speedometer requires an inline calibrators (Hypertech, Rough Country, YellowBox, etc.). Really, both need to be used to get everything back to normal, just using an inline calibrator causes other weird things like indicated cruise speed not matching the speed shown in the cluster (pretty common complaint).
    Feb 2006
    Pineville La. US
    771
    Quote Originally Posted by SlowNStock View Post
    Thank you for the explanation, & I definitely will.
    SoCal
    1,591
    any way to get your tuning reference in word or pdf? Would like to be able to read ofline.
    Thank you
    Jun 2020
    9
    Thank you!
    Updated the original post to V1.1 - fixed a few items, made some updates to try to improve readability, added quite a bit more on spark, added some transmission info, and added a list of common channels.
    Based on a number of requests, the link is now to a PDF copy of the file.
    Tune Scaling Tool: Tundra Scaling.xlsx
    Hello Slownstock,
    Could you please explain how to tune transmission to shift faster.
    also how to tune torque reduction tables.
    thank you in advance.
    Dec 2021
    8
    Any 2019 tranny tables out yet? Procharger sold a prototype to my client with on ECM tables, needless to say the trans died 5 times already...
    Sigh, how can you do half a tune guys?
    Advanced Tuner 4wheelinls1's Avatar
    Jun 2009
    Melbourne Australia
    284
    Quote Originally Posted by walter1967 View Post
    Not all the calibration data is available in all Toyota through OBD2 port, the calibration resides across multiple chips, its a bugger.
    Jun 2009
    Melbourne Australia
    284
    Well documented excellent write up.
    Quote Originally Posted by Mr.AT View Post
    Hello Slownstock,
    That depends on what you mean by shift faster - WOT is largely fixed, but you can improve part-throttle upshifts quite a bit by working shift schedules to target 100% output shaft torque retention across the shift. The factory shift schedule logic is generally aimed around input shaft torque retention. Here's a simple tool that will calculate both figures for a given shift: Shift Scheduling Helper.xlsx
    If your calibration has the trans pressure tables defined, you can make some small changes; in my experience, shift harshness goes up more quickly than shift times come down with that approach, so I tend to leave them pretty stock. There are other ways, but I haven't done enough testing to share them yet.
    For torque reduction tables, it helps to convert and work with a percentage torque reduction, here's a tool for that: Torque Management Helper.xlsx
    Torque reduction for downshifts can be solved for fairly easily - by calculating the torque before/after the shift, we can determine a torque reduction value that will match the engine torque value after the shift. This works well for a downshift because we don't need to worry about decelerating anything on the input side to mitigate shift harshness; upshifts are trickier, though, because we want to match engine torque but also need torque management to help slow down everything forward of the input shaft to mitigate shift shock. We can calculate the upshift torque management with enough information (friction torque, rate of timing reduction, inertia), but it's far easier to just iterate from the stock upshift values - decrease the torque reduction by 10% in each iteration until you reach an acceptable level of harshness, then try smaller steps in each direction to fine tune from there.
    For all of the above, I'd suggest redefining table axes to get more usable ranges.
    Quote Originally Posted by 4wheelinls1 View Post
    Appreciate the feedback! Some of the information is out-of-date at this point; eventually, I'll post an update to the entire document with some examples.
    Jun 2009
    Melbourne Australia
    284
    It might be worth adding in regards to Forced induction where the air box and MAF is stock I have seen lots of people try to adjust the fuel in the MAF curve and not the Load Multiplier where it should be. People raise the MAF in error causing the ECU to reach its maximum flow in error. Once the injector constant is set the fuel can be dialled in using the Load multiplier relative to boost, also when manifold referencing the regulator. The MAF is calibrated on the bench and is stock and best left, rectify the tune in the place the mechanical change was made.
    Jan 2023
    PNW
    9
    WOw,,, this is a spectacular guide!!!
    I'm eager to play with my Sequoia Next week.. Things have really changed since I was last in an ECU. I don't think I ever appreciated how straightforward a 90s DSM ecu was...
    Feb 2023
    SoCal
    20
    Just curious, any new information to be added yet?
    Quote Originally Posted by ryanallaire View Post
    There are quite a few updates that are needed now, but probably won't get around to updating that document or uploading some new tools for a while.
    Feb 2023
    SoCal
    20
    Ok no worries, do you happen to have an example tune with modified shift points? I'm having an issue with 4th gear even just changing app% and leaving OSS numbers stock...
