Issue with Blackvue GPS data
In the last I've tried to pull in my dashcam videos from my Blackvue camera but RR was never able to deal with the GPS data. I wrote a script to extract the NMEA data and clean up the bad formatting.
However, now despite the data looking clean when I pull the data into RR what is supposed to be 16+ minutes of data is shoowing 24 hours and 16+ minutes. It seems to choke up about 7-8 mins in
Anyone else run into this?
I have attached a few files.
FIRST minute segments ...
1. RR_Data.txt - The RR extracted GPS data for a one minute video segment
When I use this data file, RR shows 99+ hours of data. This file should be one minute of data
2. extract_all.txt - Uses exiftool to pull out the NMEA data and filters to just RMC, GLL, GGA sentences
Similar to above, 99+hours ... however if I use just the GLL records, for example, it lines up the data. But only for this segment.
FULL session...
3. session.txt - Just GLL sentences for the 16 min session
This shows 24 hours and 16 minutes-ish and somewhere around 5.5 minutes the data seems to stop for 24 hours and then starts again (according to RR)
Looking at session.txt, I cannot see any bad timestamps. They count up perfectly.
session.txtRR_Data.txtextract_all.txt
