Page 8 of 26 FirstFirst ... 45678910111218 ... LastLast
Results 141 to 160 of 520
Thread: lean area around 2500ish rpms-2014 ctsv
  1. #141
    Tuning Addict
    6,856
    It's a baro for max boost setting. Your baro axis was changed to decimal places to max out boost capability from the looks of it. Most people just make it straight 255's in the table, but yours had the axis drastically lowered. Shouldn't fix the problem, just something I noticed.
    ~Greg Huggins~
  2. #142
    Feb 2018
    830
    Specific rpm in PE? I may have overlooked it in PGA2B's log. Was waiting to hear back from him. Short of purposely putting in the wrong injector data and skewing things I'm not entirely sure on it yet. Wish I could get in and look at coding to see what's primarily different between these and the ZL's.
    Greg, here you can see the lean spot at WOT. Keep in mind this log was from a tune that i had long ago and doesn't reflect what I currently have. This log is with I.D. 850s
    2-3k rpm lean area WOT.hpl
  3. #143
    Advanced Tuner JayRolla's Avatar
    Mar 2021
    223
    I dont remember why I changed it that way. Everything starts to blend together after so many changes. LOL. I wonder if switching to speed density, failing maf and disabling o2's would make any change. Or if switching just to maf would make any difference.
  4. #144
    Feb 2018
    830
    Quote Originally Posted by JayRolla View Post
    Nope it doesn't make a difference....lol. I've tried already. Lean spot is there even in OL
  5. #145
    7,837
    Nobody's logging (that I have seen) Air Calc Mode, but we're sure it's not that? Like sure-sure?
  6. #146
    Feb 2018
    830
    I have no clue what that even is...lol. Care to shed some light?
  7. #147
    Mar 2021
    223
    Not sure what that is either but I'll toss it into the log next time.
  8. #148
    7,837
    https://www.google.com/search?tbs=li...calc-mode+lean
    Greg's posted in most of the relevant threads so it's probably nothing related, it's just still bugging me that nobody's said definitely that it's been ruled out. I don't even know if a solution was ever found or not. Or if whatever the cause was turned out to be something totally different.
  9. #149
    Tuning Addict
    6,856
    This is actually somewhat why I was asking the different pedal rates at which this was happening. With the heavier pedal inputs that it seems to be happening at, the ecm will "lean" more towards the VE even though air calc should still say high speed, but different VE's have been tried with no benefit. We can try the SD patch and then run MAF to see if the problem is gone, but with the baro being separate it shouldn't matter on one of these unless it's just something in this OS which it's looking like.
    Then if it's still present at exactly 2500 even in SD, it's definitely OS related. I'm not finding that many changes - rpm related - between a ZL and the ctsv that we haven't tried other than idle torque which is less negative on the ZL... So I guess try the SD OS with the patches - your thoughts Blindsquirrel?
    ~Greg Huggins~
  10. #150
    7,837
    There's soooo much in the ECM that isn't shown in the editor. I mean, a guess based on just intuition, there could be a table, or settings in a table, in one OS (or platform) that doesn't play nice with having injectors changed. There's people who would know that kind of thing first-hand but I sure ain't one of 'em.
  11. #151
    Advanced Tuner PGA2B's Avatar
    Nov 2004
    St. Louis, MO
    475
    Adding Air Calc Mode and MAF Sensor Sate to my channels.
    2013 OBM A6 CTS-V Coupe
    Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
    2006 Black Raven STS-V (Traded In)
    Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
  12. #152
    Feb 2018
    830
    Thing is I wonder how all these "well known" tuners are dealing with it? Are they just ignoring it? Or maybe they have a solution
  13. #153
    Tuning Addict
    6,856
    Like I said, I haven't run into it before - at least as far as I know except for possibly the one that I was sure I had fixed with making the injection timing sooner for ethanol. It has to be OS and car build specific. Zl1's don't do it and that's pretty much the exact same car minus some weight and features.
    ~Greg Huggins~
  14. #154
    Mar 2021
    223
    Does the zl1 have the same ecu and if so anyway to slap that OS onto our ecu?
  15. #155
    Tuning Addict
    6,856
    Do a write entire. This won't swap all 7. Think it just gets 5 of them. Got them out of a manual 13 ZL1
    ~Greg Huggins~
  16. #156
    Mar 2021
    223
    Well that didnt fix it. But I am getting some fun pops and bangs on decel and between shifts. Running a bit rich but nothing major. Also noticed I hit like 80-100tq more on this OS than the old one which is kind of strange. I have contacted a very reputable remote tuner that does a lot of LSA cars to see if he knows anything about this issue. Will keep everyone posted if he finds anything.
  17. #157
    Feb 2018
    830
    yeah, please keep us updated
  18. #158
    Mar 2021
    223
    Have not heard back from the tuner. I am guessing he is super busy and was going to look at this on the side but not sure what more he will find if the knowledgeable people in the thread has not found anything.
    I did find something new though. I failed my math and started to dial in my VVE table more and I found that not only do I get a spike at 2600rpms I also get one at 1600rpms. I could not feel it or see it on the wbo2 since I am not in those rpms much but once I saw my EQ Err log I saw the spike. I then went out and verified its happening on the wbo2 also. Kind of peculiar.
    I have uploaded a pic of my log file that shows the spice in the EQ ratio, its very noticeable at both RPMs.
  19. #159
    Feb 2018
    830
    I've seen the exact same thing. The 1600 rpm one wasn't as noticeable as the 2600 rpm one for me. My VVE logs look pretty similar to what you have shown
  20. #160
    Aug 2018
    295
    My 14 ZL1 did it at 1600 and 2600, too. But only if the MAF was failed. Once it was blended again, it was fine. In short- I ignored the spikes and all was fine once running a blended tune again. After that, I started tuning the VVE from the MAF and don't bother failing MAF anymore.
