Page 15 of 26 FirstFirst ... 511121314151617181925 ... LastLast
Results 281 to 300 of 520
Thread: lean area around 2500ish rpms-2014 ctsv
  1. #281
    Advanced Tuner PGA2B's Avatar
    Nov 2004
    St. Louis, MO
    475
    Quote Originally Posted by JayRolla View Post
    Are you also monitoring this area with a wbo2? I sometimes dont get a stumble but stiill see the lean spike. I flashed an entire zl1 tune over that ghuggins did for me and no change but not sure if he kept the zlq ve reversion and dynamic airflow gain tables. I might try this tonight and see what happens.
    Yes I have a WB O2. I didn't pay close enough attention to my WB readings. In the beginning I felt it and thought it was mechanical and, of course, was worried. But once that was ruled out here we are.
    2013 OBM A6 CTS-V Coupe
    Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
    2006 Black Raven STS-V (Traded In)
    Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
  2. #282
    Advanced Tuner JayRolla's Avatar
    Mar 2021
    212
    Quote Originally Posted by PGA2B View Post
    Next time your out watch that o2 and let me know if you see the spike like I do. I might try what you mentioned here on lunch.
    2013 CTS-V Coupe M6 - 1 7/8" Headers, 3" x-pipe, stock mufflers, Airaid intake w/green filter, ID1050X injectors, DSXtuning flex fuel kit, DMS under hood tank, upgraded pump, 3/4" lines, griptec 2.4" pulley, solid isolator, 100mm idler, reinforced brick, MM mild catch can, AEM 30-0334 wbo2, 600whp/630wtq
  3. #283
    Mar 2021
    212
    Yeah, airaid, green filter, 7/8th headers, no cats, 3" xpipes to stock axle back exhaust.
  4. #284
    Mar 2021
    212
    Try to take a ZL1 tune and copy over the VE Reversion & Dynamic Airflow gain tables. I did that and made some changes to my intake volume and transient tables and today I did not feel the stumble. Remember I have an automatic. But it use to do it in manual TUTD mode and slightly in normal drive mode and today it was gone.
    Which tables exactly are you talking about when you sayd dynamic airflow gain?
  5. #285
    Feb 2018
    830
    under prediction coefficents
  6. #286
    Feb 2018
    830
    no dice on the populated reversion and dynamic gain tables. Made my car very jerky and the lean spot is still there. I even tried just the reversion table, but that didn't work either. The short log below is with both the reversion and dyn. gain tables populated with ZL1 values. If you go to 4:38 you can the populated tables actually gave me MORE lean spots instead of getting rid of them.....maybe there's something to that. You can see the three humps
    copied ZL1 Reversion and Dyn. gain tables.hpl
  7. #287
    Mar 2021
    212
    Quote Originally Posted by sgod1100 View Post
    Hmm, does seem your spikes are happening more often, 1600, 2200 and 2500rpms. Not only that but the spikes happen are few hundred rpms different now sometimes. I see it at 2700 rpms instead of 2500rpms on the end of the log. This is the 1st time ive seen a change from a change in the tune.
  8. #288
    Feb 2018
    830
    Yeah, and i could definitely feel those as well. Bad part is there were sooo many tables that were changed I don't even know where to start adjusting shit
  9. #289
    Nov 2004
    St. Louis, MO
    475
    Scott- Compare the files I sent you from 6.22 and compare to 5.31. Those are the most recent changes that made the difference for me.
    Sorry guys. I've changed so many things from stock that it wouldn't be worth it to post the tune I am using.
    Jay- PM me your email addy and I can send you the tune if you want to see it.
  10. #290
    Mar 2021
    212
    I remember I already did the zl1 tables like you did and it ran so bad I just immediately pulled over and flashed back. I didnt even look at the log.
  11. #291
    did this ever get solved? if not pm me.
  12. #292
    Feb 2018
    830
    Quote Originally Posted by ctsv2011 View Post
    Nope, not yet. Ghuggins gave me another suggestion, but I haven't had time to try it yet
  13. #293
    Oct 2022
    5
    I have an 09 CTSV, I dont have any lean issues around 2500. Maybe you can find what youre looking for in my tune, i'll post it when i get to work. Also, if you see something that you believe to be wrong, please dont hesitate to let me know.
    -Lyle
  14. #294
    Feb 2018
    830
    Quote Originally Posted by LP1 View Post
    I have an 09 CTSV, I dont have any lean spike issues. Maybe you can find what youre looking for in my tune, i'll post it when i get to work. Also, if you see something out of the ordinary or something that you believe to be wrong, please dont hesitate to let me know.
    -Lyle
    Sure, I'll take a look. Do you have a log confirmation that there isn't a lean issue? Reason I'm asking is that during WOT you won't feel it (at least I don't feel it during a WOT pull).
  15. #295
    Oct 2022
    5
    I'm sure I have a WOT pull somewhere. I'm gonna throw it on the dyno tomorrow and I'll be able to grab one for you.Attachment 134461
  16. #296
    Feb 2018
    830
    Cool, appreciate the help
  17. #297
    Oct 2022
    5
    No problem buddy, hopefully it'll help
  18. #298
    Mar 2021
    212
    What modifications do you have. Everything from what kind of intake to size and brand injectors would help. Thanks!
  19. #299
    Oct 2022
    5
    427 stroker, ported sc, 2.8" upper/10" lower/100mm idler, ZL1 lid, innovators west harmonic balancer, cwa 400 intercooler pump, stock LSA heads, BTR stg. 3 pds torquemax cam (223/246 .610/.600 117+6), 3" intake, LSA throttle body, I.D. 850 injectors, stock fuel pumps (I think), DSX aux. fuel pump/E85 sensor, speed engineering 2" headers, x-pipe, magnaflow mufflers, no cats, stock transmission/torque converter
  20. #300
    Advanced Tuner Cringer's Avatar
    Aug 2021
    Somewhere smoothing your VVE table
    550
    I am guessing you will have the lean spot since you have ID850 injectors. My theory is that the spray pattern of the factory LSA injectors is different than other factory (and aftermarket) fuel injector spray patterns. Presumably this could be overcome with a transient fueling correction...but...this one hasn't been solved yet, so who knows.
    A standard approach will give you standard results.
    My Tuning Software:
    VVE Assistant [update for v1.5]
    MAF Assistant
    EOIT Assistant
