Results 1 to 16 of 16
Thread: Old customer can't login to new website
    Apr 2013
    8
    I purchased the VCM suite with 3 licenses and the usb to OBII in 2013 and used one license to tune my 06 GTO. I went on a vacation and now the website is changed and I can't access my account. My credentials work on the forum but not my account to access my software application key. I have submitted a ticket and was asked to provide a picture of my unit serial and have not heard back since. Please help
    13,585
    Create a new account, we all had to do it.
    Then add your MPVI into the devices section and everything should sync back up.
    Apr 2013
    8
    I attempted to do that myself but I don't have my application key anymore due to my Cox getting shut off. All I have is my Serial# from my MPVI and an open ticket.
    13,585
    Open the editor and put your MPVI into the computer, then click the blue information dot. Click the information dot again and it will bring up all your data on the MPVI. All the cars you have a license for and the current application key.
    Apr 2013
    8
    Thanks for the tip and I will attempt it again tonight and let you know.
    Apr 2013
    8
    Ok I don't see anything that says application key but I tried whatever I thought might work. I tried to put it in
    "My Devices" on in the dashboard and got invalid key in all fields and in VCM Editor - Help - MPVI Application Keys. Here are my results to see what I'm missing. Thank you!!
    9/21/2020 5:28:05 PM
    VCM Suite Product: VCM Editor 4.8.7
    Operating System: Windows 10 (build 18363)
    Microsoft .NET: 4.0.30319.42000, 4.7.1 or later
    CPU: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
    Available Memory: 11,723 MB
    Device ID: 1217416733
    Available License Slots: 407/409
    [Specific Vehicle]
    2006 Pontiac GTO (8 cyl), 86YMUMM053503RAS, [2006 GTO TN], (GM: 2)
    Hardware: 0121
    Firmware: 0121
    PartNumber: 0000006220
    BuildDate: 11/20/2012 12:00:00 AM
    InterfaceOnTime: 00:22:30.7150000
    ROM: 00 3F 00 81 00 01 00 00 FF
    Config: CC 88 00 00 00 40
    System Info: F7 00 00 01
    Comm Errors: 40 00 00 00 00
    SPI Info: 40 15 FF FF 4E 41 00 00
    VehicleConnectedTime: 00:22:30.7800000
    DetectedProtocols: CAN
    Protocol Info: ISO 15765-2, J1962: CAN, 500 kb/s
    ECM: 7E8, CAN - E40, GM Gen4 V8
    VIN: 6G2VX12U56L564863 - 2006 Pontiac GTO, 6.0 L, V8
    Serial: 86YMUMM053503RAS
    OS: 12604792
    Calibration IDs: 12604792, 92189027, 92189029, 92189031, 92189033, 92189025, 12597760, 92189034
    Calibration VNs: 00000090, 00007C83, 000009DB, 000071A3, 00002147, 0000781E, 000019D4, 000053AF
    Basic PIDs: 43
    Trouble Codes:
    Controller Type ID By OS: 5020
    Diagnostic Requirements: None
    Scanning Methods: ISO 15031-5 Mode 0x01 Functional, ISO 15031-5 Mode 0x01 Physical, SAE J2190 Mode 0x22, HPT Mode 0x23, GM Mode 0x2C 0x2D 0xAA, CAN Listener
    13,585
    I guess support will be the only way.
    My application key comes right up when I do it on mine.
    Apr 2013
    8
    Well hopefully they see me here since I haven't heard back since covid hit. Thank you for your help.
    28,287
    what is your ticket number? we have no outstanding tickets from March when covid hit...
    Apr 2013
    8
    HP Tuners Support <[email protected]>
    May 21, 2020, 12:29 AM
    Ticket ID: 220187
    Subject: Old Customer
    Department: Support (Existing Customers)
    Type: Inquiry
    Status: Open
    Kind regards,
    HP Tuners LLC
    28,287
    I've responded to that ticket, back on May 21st and when you reopened it on sept 15th.
    I simply asked for a picture of the back of your interface, we recommend checking your spam folder as we've already responded promptly.
    Apr 2013
    8
    I did respond with a picture of my unit and never heard back. I have emailed you a picture of my unit and the responses I received afterwards.
    Thanks for your help.
    Apr 2013
    8
    I am back in business! Thank you
    28,287
    Dec 2006
    Pensacola, FL
    490
    I'm having the same problem, except I have my device ID and application key. When I click import, it tells me that my MPVI is owned by someone else. Please help, Thanks,
    Rob
    28,287
    Quote Originally Posted by HartRod View Post
    Rob
    Open a support ticket please.
