Originally Posted by
drumnbasslvr
I have never run NN on a vehicle began life as a naturally aspirated engine and now is boosting. I make things simple to start. Turn off that NN, blanket the entire PE to 0.0192 for 11.5 AFR, then simply tune the airflow VE table to get things in check, use the long term feedback to handle your trims part throttle, use wideband afr error to correct your wot fueling, (AEM OBD2 4.9 wideband works brilliantly for this), or use yours, fix your injector data, pretty stock for numbers at a glance, multiply your knock tables by 1.2 to start, ensure you are never below 5 degrees in wot ever, change your wot voltage to 2.7 ( I changed a 2015 challenger 5.7 whipple tune today to 2.0 which helped, they build boost instantly so all the better ), change that voltage in power enrich and torque mgmt, put your throttle voltage stuff back to stock. Log more parameters! Your log looks like a whole bunch of just enough but not enough to diagnose well.
PS I'm not touching that neural network trainer yet because, yes it looks cool, but comes with zero instructions.
