Results 1 to 17 of 17
Thread: tech 2 where to get
    Jul 2020
    tn
    40
    tech 2 where to get
    cicne hp tuners wont' do idle relearn and im tired of dealing with
    TB swaps that need relearn cleard
    whyat do you gues use or where can i get a tech 2 cheap?
    are the knock offs for $200 bucks any good
    all i need to do is the freking idle relearn...
    gen 3 P59
    Any good scanner-snappy launch etc will do it. Tech2 was discontinued after the 13 model year.
    7,847
    The Chinese MDI clones do work - I have a VCX Nano - but the software setup and config can be a huge pain in the ass. You should be aware before hand that all the software is essentially pirated so there are cracks and patches and workarounds you have to do to fool everything into working. I am using mine only for pre-2009 or whatever the breakpoint is, so only need Tech2Win & the (old, outdated, no longer supported) offline version of TIS2000 for programming, but apparently there is other software that can do programming and diagnostics for the later GDS2-only based stuff.
    Jul 2020
    tn
    40
    Installation Tips: Pls turn off anti-virus software before install, make sure your computer at least 4GB.
    this is why i don't trust the chinese stuff
    ok yea i was woindering
    its 2004 and all I need is that dang throttle relearn crap
    i see these all the time
    https://www.obd2tool.com/goods-1568-...ZUHolden).html
    Isn't there a software emulator called Tech2Win?
    Waldorf MD
    774
    I use the VCX Nano also. Getting the software installed is INDEED a pain in the ass BUT IT IS WORTH IT. That little thing is a TechII, MDI, and SPS tool all in one! That thing has saved SEVERAL of my customers asses due to tuner error. I recently had to fix someones tune BUT they didnt have a stock file AND they were running a 3 bar OS. I was able to use SPS to pull an updated STOCK OS from GM. I was able to "marry" my ECM and TCM when I replaced the trans in my G8. Helped a buddy out when he had to replace his BCM in his car. Helped someone program new keys in his G8 when he lost ALL OF THE KEYS (Cant do that without SPS).
    This little thing is worth ALL OF THE 99 BUCKS I PAID FOR IT. Support from the company is not great because of the language barrier. Outside of that, this little thing is GREAT!
    Daily Driver= 2003 BMW 330xi
    7,847
    Quote Originally Posted by tune2mbt View Post
    Yes there is, but it requires an interface device to translate PC/Tech2Win-speak to OBD-speak, just like VCM Suite software requires a MPVI.
    Waldorf MD
    774
    Yes. The VCX Nano software comes with it.
    Yea, I picked up an original MDI off eBay. I had the VCX Nano. It was all hacked SW and buggy as hell so I returned it.
    I didn't want to take a chance writing anything with buggy HW/SW. I suppose it will work in a pinch.
    Waldorf MD
    774
    Being an IT Techy Tech, I was able to figure their software out. Like I said earlier, their customer service leaves EVERYTHING to be desired. I haven had any issue with my VCX Nano at all. And its saved a few friends asses in the process...
    Nov 2020
    8
    I have a Chineseium Tech2 and have used it on multiple vehicles over the years and it works great. I did have to replace the OBD cable. I think I picked it up on eBay. The case for it is also available and comes in handy. I keep an old Panasonic ToughBook running an ancient version of windows for the TIS2000 software.
    If you have aftermarket radio and other stuff, you will encounter some of the same communications issues you see with HPTune devices.
    Jul 2020
    tn
    40
    so for ush non IT techy gues who does not want to spend dayys dorfing with software... hmm what to get>???
    SoCal
    1,590
    I have Tech2Win but I have been using a Bluetooth OBDII connector from Amazon and a android program called Throttle Reset. Works pretty good and free.
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    I have never had a tb i could not relaern with hpt
    ever
    and ive done thousands, on the tuning side, and part of repairs
    the scanner does nothing more than access the "modes" built into the ecm from the factory.
    Your likely not meeting all of the criteria needed for the reset. And if thats the case, the tech 2(or tech 2 win, mdi with gds) likely wont either
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Jul 2020
    tn
    40
    hmmm
    Quote Originally Posted by mbray01 View Post
    ever
    then please explain the procedure you use on a P59 computer
    Apr 2020
    4
    Quote Originally Posted by tnbubba View Post
    I am waiting for the answer as well.......
    7,847
    I can tell you've put in lots of hard work educating yourself on this, so I will help you out!
    https://www.acdelcotds.com/subscriptions
    Scroll down to the bottom, you can get access to the full service manuals just like the dealership techs use. Have fun!
