having a start up issue . stalls after warm start up only. ls1.ls6 intake , summit stage 2 cam and long tubes. tuned ve ,and maf with wideband. ive ran idle configurations , adjusted throttle blade with in its limits and reset tps and iac with still no head way. ive adjusted base airflow with inflated numbers to do the best it will since the ones i put in from desired air flow and only made the issue worse
working tune.hptstart up.hpl
