I have been working on a heads and cam this week, and came across what I though would be a good idea, and sure enough it helped.
My tuning method for VE:
1. Set MAF fail to 0
2. Set up the AFR histogram (if you haven't already).
3*. Connect to the car, and under VCM control in the scanner turn off closed loop.
4. Start the car and do the normal driving around and logging.
5. Take the AFR% error and apply it to the VE table.
Step three was a change from everything I read here. My problem was that the STFT and LTFT (even when reset) would start to influence the AFR during the 30 minute loggin session. By forcing it open loop in VCM controls it will no longer apply LTFT and STFT while driving.
This meant that the AFR results were driven purely from the VE table and not influenced by STFT at all during the logging. So my results were MUCH more accurate.
This small change made a huge difference, as it only took two driving sessions to get the VE very close. Before the STFT were skewing the AFR results and I had to make repeated passes until the STFT were small enough.
