Results 1 to 8 of 8
Thread: 2010 Camaro Trans Setting Needed
    Dec 2020
    How do I stop my A6 from going to 1st at a stop? Want it to stay in 2nd. I have 3.45 gears now and with the SC, 1st is useless....
    Apr 2014
    North Dakota
    64
    I don't think it is possible, but not sure why. I have 6l80 on my truck and the lowest 1-2 shift point I can go to is 9mph. It might be a BCM thing, or just other code in the TCM.
    The only way to start in 2nd is with TUTD.
    2014 Silverado L83 | Knockoff S369 Turbo | LT1 Fuel Pump and Injectors | MAST L84 Port Intake | MS3Pro Secondary Fuel Computer
    Jul 2020
    VIC Australia
    1,182
    So putting 0 in the 2->1 shift doesn't work? Works fine in my 6L90 (2013 ZL1 / HSV)
    Dec 2020
    Quote Originally Posted by MORLOK View Post
    It was done with my SCT tuner...Long story why I changed to HPT but HPT tuner can't find it or won't do it. But he is a prick and I'll leave it at that....
    Not sure, I relied on the tuner and haven't messed around AT ALL with HPT and wouldn't know where that setting is... But with that hint I'll start looking....
    Advanced Tuner robbyredneck's Avatar
    Jan 2010
    fingerlakes ny
    356
    where specifically is this 2-1 hjtrbo?
    04 6.0 silvy china turbo
    87 gn
    03 stroker evo ww
    00 ss camaro
    Jul 2020
    VIC Australia
    1,182
    Hope this points you in the right direction. There are 3 tables. If that doesn't work it might be an OS thing. This table is in a T43 TCM for a '13 ZL1 6L90.
    its called winter mode, my 2016 truck will start in 2nd from a stop, my issue is it doesn't shift thru the gears in winter mode it just stays in 2nd, and you have to manually shift up
    2,875
    Compare against a LSA auto car. CTSV or ZL1 They use pattern B as normal mode. It will shift out of 1st the first time you leave but after that it will never downshift back to 1
    Tuner at PCMofnc.com
