AEM 03-0306 Boost
Info needed
I found that VCM Scanner Beta has this channel from External Inputs/AEM/X-Series Boost Gauge (30-0306)/Boost Pressure
How to add/connect this gauge into Scanner. I see the gauge only with Analog to A/D Prolink. I don't see the CANbus integrated like AEM AFR X-series. Are they compatible with AEMNet CANbus to Prolink CANbus input?
little confuse here without good instruction on how to add in.
https://www.aemelectronics.com/files...ns/30-0306.pdf
The 30-0306 does has CAN data. But, I don't think the CAN pins are populated in the connector. They are easy to add. But... I don't think VCMScanner knows how to read MAP data from AEMNet ?
same thing with question mark in this head.
Should we do an experiment again on this?
test CANbus bitrate 500kbps AEMnet (transmit 20hz) vs Prolink (sampling 100hz <-flex rate??)
ended with wrong reading. =overwhelming=
Was the AEMnet used with VCM scanner using the boost gauge?
