Hi guys,
I was reading about this issue because I think I'm in a similar position.
My car (Whipple SC in a 16' Mustang GT) was making 780WHP with only E20 and nothing of knock. Now, I stroked it to 5.4L and add a +20% balancer with a 3'' SC pulley.
First, I reduced 10 degrees just to be sure for the borderline table and I?m using E85 but still car is pulling 10 degrees and was making like 550WHP, I limit the knock retard to 5 degrees, and it gets to 650WHP with 10 degrees of timing I think is too low.
Because of my new pistons and crankshaft, I know knock sensitivity changed so I removed 20% of all KNOCK SENSOR GAIN which says, ?This defines the sensitivity of the knock sensor, higher values are more sensitive.? But nothing changed. I don?t think there is detonation with 10 degrees and E85, specially because I?m 7800 feet over sea level so compression inside cylinder is lower.
What do you guys think?
dperformance are you running global or per cyl retard? If per cyl, I would suggest logging the kr for all 8 at a high data rate and few other pid?s to see what each cylinder is doing.
