Results 1 to 7 of 7
Thread: Help, accidentally pulled 2 wires out of my MPVI Pro 8 pin connector
    Mar 2017
    10
    Help, accidentally pulled 2 wires out of my MPVI Pro 8 pin connector. 1 is a ground that I put back in pin number 5.
    Not sure where to put my AEM sensor lead, I can't tell from looking where it came out of. vcm_scanner_eio_plug.jpg
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    you can put it into any of the 4 a/d inputs. Most just put it in the 1st one.
    Mar 2017
    10
    Now I'm not getting any "power on" light on the HP Tuners box? The cig lighter power is good
    Mar 2017
    10
    is there a pin out diagram for the box end of the HP Tuners cable that goes from the OBD port to the HP Tuners box? Then I could check for voltage at the box end of the cable
    Mar 2017
    10
    Bill, I really wish you guys had a phone number for help. VERY AGGRAVATING.
    I'm trying to figure out why my box lights don't come on. I checked all 16 pins for continuity on the supplied cable that goes between the OBD port and the HP Tuners box. All 16 had tone so I'm assuming my box is bad?
    any help would be appreciated. Attached a pic of the box for reference
    Mar 2017
    10
    Update, I just plugged the cable into another vehicle and the power light comes on, so maybe I have a blown fuse for my OBD port? 2003 Z06 Corvette. Does anybody know where it's located?
    Mar 2017
    10
    Ok, so I found a blown fuse in the passenger floor panel, and for anybody else the code is C/LALDL and is fuse number 29. 10 amp
