Hi
I have an LS6 engine (out of 2004 Corvette) in my 68 camaro and wondering if it is possible to connect the 30-4110 wideband White wire (0-5V) to EGR pinout 55 from 411 PCM blue connector. pin no 55 in blue connector is empty because most likely the 2004 engine did not come with RGR
I have found various threads about the same topic but could not reach to any conclusion. Some people said it did work for them and some say the new MPVI2 standard no longer works this way by using EGR signal, and the only option is to get the pro version which is $250 more than the standard for just linking the wideband into the MPVI2.
Thanks in advance
