Has anyone else noticed that the Equivalence Ratio Commanded is way off from actual WB EQ Ratio? I've noticed on my non-EcoBoost and EcoBoost logs that say I commanded 0.85 lambda, my WB EQ Ratio actual is 0.85 but my Equivalence Ratio Commanded is something like 1.19
I recall from GM tuning that equivalent ratio is the inverse of lambda, so if I do the inverse of 1.19 it is about 0.85
Is this the reason why the EQ Ratio Commanded looks this way? I know I am not running/commanding it to be THAT lean. I can do a Math parameters and inverse it, but seems weird that I'd have to do this extra step.
