Results 1 to 12 of 12
Thread: Pro-Link Wiring to AEM 30-0300
    Nov 2020
    Can someone please validate how to wire the Pro-Link to the AEM 30-0300? Its a non CAN BUS LS1.
    Pro-link Directions
    - Black ? GND --> This is clear
    - Red ? Analog 1 --> Which AEM wire? White? or Brown?
    - Blue ? Analog 2 --> not used if I use the Red wire?
    - Orange ? CAN High --> not used in my application
    - Yellow ? CAN Low --> not used in my application
    Its been frustrating try to find a clear answer. Almost everything I have found is how to get he AEM CAn guage to read analog, or something like that. Any clarification is appreciated, I just dont want to change burning this thing up.
    Prolink black to aem brown
    Prolink red or blue (your choice) to aem white
    That is it
    Instructions:
    Pro-Link
    AEM 30-0300
    Jul 2021
    5
    Quote Originally Posted by r0cket View Post
    Pro-link Directions
    Jul 2021
    5
    r0cket did you ever get yours working? I am having the same issue with the 30-0300 and the prolink. The wiring instructions are so simple and every video makes it too easy to understand and hook up, yet it doesn't read in hp tuners properly. I couldn't get it to work with the serial Port so I gave up on that route. I'm starting to think I have a defective guage..
    SoCal
    1,593
    Had this issue also. Turned out to be my settings in the scanner. I was using the wrong input. When I get home I will check and see what it was I did.
    Jan 2021
    7
    following
    Jun 2023
    3
    Did you figure out what setting you changed?
    Sep 2012
    CA
    45
    I'm having issues with the serial for my AEM wideband also. The Prolink works fine. But when I hook up to Serial, I am seeing a 18.3EQ ratio being read in the scanner. It just stays stagnant at that number when the engine is running. Transforming the output makes no difference. I read somewhere that the pin # on the serial plug might be off. Pin #2 Rx and Pin #3 Tx output. I might try switching the wires to see if I get any data that way.
    Apr 2023
    Quote Originally Posted by chrisxiv View Post
    I'm having the same issue. Let us know what you find out
    Oct 2023
    8
    Old thread, but still following. 😅
    Feb 2024
    Pro-link Directions
    I just dealt with this today installing my pro-link/mpvi3/aem 30-3000 wideband. Wired everything up using the white analog output from the aem to the red on the pro-link, and the brown from the aem to the black of the pro-link. I could not get the channel to display the same AFR in VCM scanner as the gauge was showing. After hours of research and trying different things, I finally found the white analog wire pin had came out of the connector on the back of the gauge. Seems to work great now!
    Jul 2020
    Las Vegas ,NV
    14
    I am currently using an AEM 30-0310 and can read AFR but not Lambda. I have been using Goatropes set ups can use the Maths to and log MAF to see AFR % difference but no changes get me to Lambda. I have the MPIV1 so I must use the serial connection. The funny thing is ,I also have an EFI V-2 and can read and log both AFR and Lambda. Anyone have any ideas. I really would like to use HP to correct the MAF andd the VVE as the process looks much simpler. Thanks in advance.
    Lanny
