& if not, is there a way to calibrate it
mine likes to hover around 4%
Drive by wire as in electronic or as in a cable throttle body??
The electronic throttle will never read zero because the blade is always open to run the engine. Probably around 10-15% at idle. A cable throttle body should read zero at idle.
i have an electronic accelerator pedal
& just to be clear, i'm referring to the accelerator pedal position, not the throttle position
i just checked over my last scan & it read 0% prior to shifting into gear
it wasn't reading below 4% when i posted this thread & i made no changes to affect the pedal
odd
sk
