Someone with some experienceFull Throttle pull.hpl11th drive.hpt look at my long and tune please. If you look at time 1:58 and look at my Desired Lambda it shows to step down. The gear before it was commanding .87 at WOT at the same cells as after the shift but what cells are making it add more fuel and commanding .70. Im sure it has something to do with the Power enrichment but what do i need to change to level this commanded out?
