Results 1 to 10 of 10
Thread: 2013 zl1 with kong blower
    hi guys
    could you please check my log/tune and help me with these questions:
    1. why afr jumping up/down when in wot. sometimes its 0.84 split second later is 0.76 lambda. Is it related to fuel pressure dropping?
    2. bank1 02 reads richer then bank2. spark plugs look ok, i changed 02 sensors. Could be this further mechanical problem or this could be related to stage 1 camshaft?
    3. your thoughts on the log in general.
    car mods:
    oem zl1 engine with cam and kong lsa blower. upper pulley, dsx external pump, e85, 1300cc inj, 112mm tb, headers.
    wot2.hplairflow_changes_maf_tbchange.hpt
    2018 mustang gt a10 with headers and e85
    Tuner BigTuner's Avatar
    May 2020
    Indiana
    111
    I have a 2013 ZL1 with similar mods that I tuned myself, I will take a look at this when I get home.
    May 2020
    Indiana
    111
    What injectors are you running btw, I will want to check out the injector data?
    Mar 2011
    Ripley, MS
    1,865
    The fuel pressure is nosing over big time. You might think about a boost-a-pump to help feed it. That'll get the injector DC down a good bit as well.
    fid 1300cc, stock fuel pump + external dsx pump
    Jul 2021
    if you tell me how to post i will help you
    Mar 2015
    Alberta Canada
    77
    Your maf curve is really rough and needs some major work as does you vve table. There shouldn't be drastic cell-to-cell variations in the vve and the maf should be a smooth curve. Looks like your data is skewed that your basing your changes on.
    69 Chevelle 418" LS3, 11.25:1,PRC 260 heads, TSP 235/239, Longtubes, dual 3", 4L80, 3.42
    2010 Corvette Grand Sport A6, Heartbeat blower, 78mm pulley/10% lower, Kooks Long Tubes, 224/232 blower cam, ID1050x's, ECS stage 1 fuel system, alkycontrol meth system
    Feb 2018
    830
    Another thing you should also do is change your spark airmass axis to go higher than 1.36 grams. You are going over 2 grams and your spark table is only going to be using what numbers you have in the 1.36 line.
    Mar 2024
    22
    Quote Originally Posted by ttbestas View Post
    hi guys
    car mods:
    Did you have any issues with the 112mm tb? I'm getting power reduction mode at 3500
    Advanced Tuner JayRolla's Avatar
    Mar 2021
    218
    I see your fuel pressure falling off but its still above 50psi which should be okay. Might need more tuning with the AUX pump, I would think that you have enough pump to keep pressure up. I believe you can add a boost a pump to the AUX pump if you are running out of fuel. Like stated your MAF and VVE table is pretty bumpy. Both should be pretty smooth. IDC is pretty close to 100%, maxing out those 1300's but its probably due to the fuel pressure dropping making them work harder. With the boost and TQ your running 26* is pretty spicy even on e85. My cts-v stopped making power on e85 at 23.5* but I am stock cams/heads. Have you dynoed it to check MBT? Here are some pics of your maf and vve. MAF needs smoothed out and the VVE table is really bad. I also posted a pic of my VVE table for comparison.
    2013 CTS-V Coupe M6 - 1 7/8" Headers, 3" x-pipe, stock mufflers, Airaid intake w/green filter, ID1050X injectors, DSXtuning flex fuel kit, DMS under hood tank, upgraded pump, 3/4" lines, griptec 2.4" pulley, solid isolator, 100mm idler, reinforced brick, MM mild catch can, AEM 30-0334 wbo2, 600whp/630wtq
