Thread: Thoughts on Ilde
    Advanced Tuner Ghostnotes's Avatar
    Feb 2012
    Houston, TX
    475
    Thoughts on Ilde
    I only get a short time when I'm home to mess with my C7/M7 but would like some criticism on the idle i have. This has LTH large cam and YSi-V7,head work. I see that the trims look good, Starts and falls into idle without surging, Timing looks ok but would like a pro to look at it in general.
    Thanks.
    I always tune VVE....
    2016 C7 M7 Z51
    Callies ultra billet crank
    Callies ultra billet rods
    Diamond pistons
    Jhonson high speed lifters
    Ported and polished headwork
    Custom cam
    YSi-V7
    Nov 2009
    All Around
    3,149
    seems like your High pressure pump is a lttle lower than normal
    as you can see its requesting 400-500 psi but only seeing about half
    could be issue with the install and the lash clearance
    Feb 2012
    Houston, TX
    475
    Never realized that, it keeps up during high pressure demand. There is no lash, It's just 10% over lobe. Was told and read at 10% you don't need a lash cap, but that was 2-3 years ago. Only thing I did was re-span the columns per the Banish DVD. Wouldn't think that would matter.
    2016 C7 M7 Z51
    Diamond pistons
    Custom cam
    YSi-V7
    Aug 2014
    Central, LA
    738
    Quote Originally Posted by SultanHassanMasTuning View Post
    This is because of his "fuel rail pressure relative" and/or "fuel pressure estimated pids. It's logging 0 so in the charts he's getting the average between actual and 0. Just remove that pid.
