I'd love to get to the MAF tuning but I'm still struggling with my VE table. I calibrated my LM1 before the process just to make sure I was getting the most accurate info, and it's accuracy looks perfect. My car's AFR margin is bad! I set minimum cell hit to 50, only have 24 bits I'm logging, & the AFR error margin is in the negative double digits (-18 in some cells). I copied the error and special pasted> multiplied % and manually smoothed the surrounding cells. I then made another 55 min long log and came up with a very high (like the first log) AFR error margin. Still I copied, pasted special> multilied % and now I have a swimming pool in my VE table!
The car was running in the 11's & 12's in the AFR.
The only 2 thigns I think I may have did wrong was
1. I never reset the fuel trims in the scanner.
or
2. Although I disabled the LTFT's in the editor I didnt disable the "fuel trim learn" in the scanner also.
Any ideas, I hope this is just another case of my ignorance.
TIA
