Hey all,
As it says in the title, it's a project. 2.4L with an E37 PCM. M62 with a 2.8. Everything engine internal is stock, has an LSJ kit bolted. Having an injector timing issue. I'm using Siemens Deka 107961 flow matched injectors. The best list of specs I can find on it are:
Body Design: Long, Minitimer electrical connector, Deka IV, high-carbon composite
Static flow rate: 62 lbs/hr @ 43.5 PSI (646 cc/min @ 3 BAR)
Overall length: 3 inches, 74 mm
O-ring to o-ring: 2.3 inches, 60 mm
Body Diameter: 15 mm
O-rings: Top and bottom, 14.0 mm
Spray cone: 26 degrees
Minimum linear PW: 1.5 ms
Open/close: 1.3 ms/0.7 ms
Part number on injector: 107961
Coil resistance: 12.0 Ohms (high resistance, saturated)
3 BAR dead time/latency offset Table:
8 volts 1.538 ms; 9v 1.231ms; 10v 0.923; 11v 0.708; 12v 0.523; 13v 0.400ms; 14v 0.308; 15v 0.215; 16v 0.092; 17v 0.000
Minimum Pulse Width: 1.5 ms
So I set the min PW to 1.5, and the short pulse width to 2.0ms (open + close ms times). I tried to set the volts under Engine -> Fuel -> General -> Flow Rate -> Flow Rate Mult vs Volts with the table they provided, and the car won't start. So I set that table to 1.250 and it starts and idles well. For the life of me, between my fueling tables and the injector tables, I can't get this thing to go. It idles well, but put it in D and try to take off and it falls over. Once it finally reaches above 2000rpm it takes off like a rocket. Best PSI I've seen was 16, but that was sitting in P and racing it up like an idiot :P If anyone has some insight as to where I go from here, I'd be eternally grateful. I know these injectors have long been discussed and there's really no good information I've found, but I'm hoping for some good news.I attached my "best" tune for the project. TIA!
