Results 21 to 40 of 43
Thread: How to soften shifts
  1. #21
    Advanced Tuner morepowerjoe's Avatar
    Sep 2021
    Austin
    292
    Are you talking about the timing pull between shifts?
    That is normal and you do want that.
    Side note, this thing is commanding a lot of fuel for a NA cam build. I'd want a wideband on this stat to fix the fueling.
    The only problem with a wideband is I wouldn't know what to do with it if I had it. lol. I'm assuming that my tuner knows of this and so I wonder why isn't he concerned? One thing is I made 438 rwhp and was hoping for around 450. Would you think that is hurting it all that much?
  2. #22
    Sep 2021
    Austin
    292
    Quote Originally Posted by hjtrbo View Post
    You create it in the scanner. Start right clicking and exploring the menus. Can do heaps of shit with it.
    So is that graph from my log?
  3. #23
    Jul 2020
    VIC Australia
    1,176
    Yep, your log.
    Tip, Don't ever touch open loop fuelling without a wideband.
  4. #24
    Sep 2021
    Austin
    292
    I've been playing around with the scanner stuff but can't seem to figure out how to get that graph you pulled.
  5. #25
    Sep 2021
    Austin
    292
    ok so I think that I see the timing pull during the shift. Is that something that I want like 5FDP said? Because I didn't see that before I enabled TR.
  6. #26
    Jul 2020
    VIC Australia
    1,176
    Yeah.
  7. #27
    Sep 2021
    Austin
    292
    Hey thanks for all your help.
  8. #28
    Mar 2020
    380
    I would raise the Base Spark table (this is used as a minimum timing floor) to somewhere around 0-5 degrees so it doesn't pull so much on shifts. It dips down around -10 degrees on shifts.
    Start logging shift times. Look in your scanner for latest shift time, and choose them all 1-2, 2-3, 3-4, etc.... This way we can help you to see if the shifts are sloppy, and if future changes help/hurt completed shift times
  9. #29
    Sep 2021
    Austin
    292
    Quote Originally Posted by village_idiot View Post
    Where do I find the base spark table? Under Engine, Spark and then what?
  10. #30
    13,582
    Having -5 to -10 degrees on the shift is not a problem, to me that helps extend transmission life on stock units.
  11. #31
    Jul 2020
    VIC Australia
    1,176
    Agreed.
  12. #32
    Sep 2021
    Austin
    292
    Well I hate the way if shifts with the timing pull. It's just to aggressive.
  13. #33
    Jul 2020
    VIC Australia
    1,176
    Your trans. Your wallet. Put it to how you like it. Enough info on this forum to search through to build your knowledge and tweak. Not something you'll male 1 change and be done with. Will take months to learn just the basics. Or take it to a trans tuner.
  14. #34
    Sep 2021
    Austin
    292
    So I've decided to not use the torque reduction. Like I said I just don't like the timing pull on shifts I just think it's too aggressive. So with that being said, is there a way to soften the 1-2 and 2-3 shifts without using torque reduction? Like maybe using the inertia factor profile like Lone_mfkn_wolf said?
    Also I'm blowing past my wot shift point, way past it. If someone could help with that also it would be most appreciated. Thanks
    wot pull.hplmy base tune.hpt
  15. #35
    Aug 2020
    335
    Quote Originally Posted by morepowerjoe View Post
    Use shift torque management and try lowering your shift MPH.
  16. #36
    Mar 2020
    380
    You could just keep guessing at it, or research it and take advice.
  17. #37
    Sep 2021
    Austin
    292
    I'm wondering if my going over the wot rpm is when I'm losing traction?
  18. #38
    Jul 2020
    VIC Australia
    1,176
    You could just keep guessing at it, or research it..
  19. #39
    13,582
    I'm not sure how the timing pull is too aggressive. That is a factory setting to have it pull power away.
    My opinion is that your shift times are too fast as well. I stop at .3000 and you are way down to .2200 and .2000. The less rpm and torque the higher I have the times as well. For part throttle I am at .4000-.4500 beacause I don't need it at .3000 or lower there.
  20. #40
    Sep 2021
    Austin
    292
    Ah I see. You got to remember that I'm starting out with two tuners modifications to my tune so I don't know what all they did. I've been comparing a stock tune file to mine but I don't really know what is too much and what isn't. Thank you for taking the time to actually look at my tune I really appreciate it. So that must be why I think the timing pull is too aggressive because it's shifting so fast the timing pull just doesn't have enough time to complete the process. So if you were me would you return all the shift times to stock and start over or just start raising the values to a higher number like say .3000? Thanks
