Results 1 to 2 of 2
Thread: Curious about changing Row and Column amount When underlined
    Dec 2016
    17
    I am working on a tune for a boosted L76 with an E-38 computer where it goes past encoded limits. I see that I can adjust the column and row values that are underlined to get more from the table but I have never done that before and it appears to change a lot of the tune so I would like to understand. Please help point me in the right direction as I have been trying to search for info with no luck. Thank you
    Jan 2016
    329
    In the E38 VVE table you can edit row and column values to whatever you want or to pre determined 2 and 3 BAR and RPM values. You loose some resolution but not a big deal.
    You will need a 2 or 3 BAR MAP sensor as well and the correct offset and slope for that part number MAP sensor.
