Results 1 to 10 of 10
Thread: 12594942 map sensor
    Oct 2021
    26
    12594942 map sensor
    Hi all, I'm getting started with my first tune. Have a question regarding the map sensor, 12594942. I cant really find any information on it. Appears to be a 1.3 bar?
    Im running a NA ls1 with aftermarket intake, which doesn't accept the factory map. I had this one laying around from a ly6 or something and thought I could use it.
    I did an os enhancement to 2bar, which allows me to set the linear and offset.
    I'd think it would be OK. But don't know the values. I have a hunch...
    Thought I'd Check.
    Thanks!
    13,585
    128.20 and -0.30 should be the settings.
    Oct 2021
    26
    That's the first value set I used. But then my key on engine off pid reads 89kpa
    Here in MN, it should be more 101kpa ish.
    Also, can't use negative offset!
    13,585
    The kpa will depend on the day, we aren't below sea level here in Minnesota. High 90's is the average I see.
    If those settings don't work then it's probably going to be 94.43 and 10.34 for the other GM map sensor used.
    Weird that is says you can't do a negative offset, the table on my computer says I can and it works for me to put negative numbers in.
    Oct 2021
    26
    I'll give it another go tomorrow.. Appreciate the feedback! Been fun so far.
    Oct 2021
    26
    MAP offset value in HPTuners software version 4.10.5 is only 0-640Kpa
    13,585
    I still running 4.6 or 4.8 because I will not update mine anymore with the recent changes they have made in 4.10.
    Oct 2021
    26
    Any examples of what they changed that was bad? Sorry, I only recently started!
    13,585
    They removed certain things tied to emissions, so those can't be turned off anymore.
    Oct 2021
    26
    I follow you. Will have to track down an old version
