Results 1 to 16 of 16
Thread: Issues with AEM X-series wideband
    Jul 2021
    16
    Part number 30-0334 aem wideband with OBD Can integration. Was working great for logging with HpTuners without gettin the Pro feature then randomly car wouldn?t start, all gauges drop to zero, all the service warnings cycle through the display, U0073 CAN COMM code. Unplug AEM obd connector, erase code and it?s fine until I plug AEM back in. They sent me a new replacement gauge and harness, same issue. I can plug in HPtuners and my scan tool to the obd port with no issues. WTF??
    Feb 2020
    Metro Detroit Area
    263
    I wired mine in directly with a bit of solder and heat shrink tubing. I dont like having things plugged into the OBD2 port all the time, especially 2 different devices. Ive had no issues with this, might be worth a try. Unless of course you're not looking for a permanent install. In that case, I'd terminate a second OBD2 port in a secondary location on the car for the wideband or HP tuners interface. Just my 2cents
    Jan 2014
    SoCal
    1,562
    Quote Originally Posted by C6maniac View Post
    Part number 30-0334 aem wideband with OBD Can integration. Was working great for logging with HpTuners without gettin the Pro feature then randomly car wouldn?t start, all gauges drop to zero, all the service warnings cycle through the display, U0076 CAN COMM code. Unplug AEM obd connector, erase code and it?s fine until I plug AEM back in. They sent me a new replacement gauge and harness, same issue. I can plug in HPtuners and my scan tool to the obd port with no issues. WTF??
    Try changing PID's first.
    Dec 2005
    604
    More likely, the ECU number.
    Jul 2021
    16
    Quote Originally Posted by dr.mike View Post
    Can you elaborate?
    Jul 2021
    16
    Just to be clear, the a/f displays on the gauge as it should. Only issue is when connecting to CAN with the obd connector. Instrument panel freaks out, throws U0073, amber security light comes on (car with the lock) and it keeps the car from cranking until unplugging the AEM obd connector. Again, it was all working fine for a cple months prior.
    Jul 2021
    16
    Quote Originally Posted by TheMechanic View Post
    To what? I never changed anything when this started happening.
    Jul 2021
    16
    Quote Originally Posted by danmw2003 View Post
    I can try hard wiring but don?t think it?ll change my issue. I tried a new obd connector harness from AEM with no change and my cars obd port pin fit is good.
    7,627
    Read page 5 in the AEM user's manual.
    Jul 2021
    16
    I?ll try cycling through all the ECM #?s now🤞🏻
    Jul 2021
    16
    Went through all 7 ecm #?s, no change. Figured that wasn?t it since I?ve always used it on default 6 before with no issues.
    Feb 2020
    Metro Detroit Area
    263
    A loose connection can cause the CAN buss to go into fits and will fault things out. My car does this occasionally when I bump the MPVI2 device or the extension I have, causes the car to not start, or if I do it while its running, it faults out the ABS, EPAS and traction control. Id solder it in IMO, or get the pins, hardshell and some wire to install a new OBD2 port somewhere else in the car. Its not likely the device, rather the connections to them. Bad or loose connections cause high resistance in circuits, not what you want on your CAN buss.
    Jul 2021
    16
    Soldered in behind the obd connector, no change.
    Dec 2005
    604
    Something is not right. The 30-0334 does not "transmit" unless it receives a specific request from the MVPI. So, connecting JUST the 30-0334, should do nothing.
    That is, it is inert, until addressed.
    Just in case the harness is damaged ( shorted? ), try plugging in the harness, without the gauge.
    Jul 2021
    16
    Without being plugged into the gauge, it?s fine. Or I can have the gauge plugged in and disconnect the obd connector and it?s fine. Just not both🤷🏻*♂️. Its a new replacement gauge and harness. Unless I got another bum gauge, Im out of ideas.
    Dec 2005
    604
    Here is a trick. You can put the gauge into BOOTLOADER mode. In this mode, it will not make or respond to any traffic, on the CAN bus.
    1. Turn the power off
    2. Hold down both buttons, on the gauge
    3. Turn the power on.
    The gauge should show something like "L1.25" or something, like that. Depending on the firmware version, in the gauge.
    If there is still a problem, starting, in this mode, it must be a hardware issue.
