"DANGER TO MANIFOLD!!"Originally Posted by MeentSS02
Sounds great, thanks for the response,,but I wish I could see a live demonstation of it when it comes out,,because it still sounds like something a computer dummy like me would struggle with. I'm still afraid to play with RTT. Just don't understand the graphs well enough. Larry.
I'd settle for just RTT on my truck...
2005 Sierra Z71 SLT CCSB (LM7)
STS GT67, LPE GT 2-3, ASP Pulley, Delphi 42#, A'PEXi AVC-R, PLX SM-AFR, FLT Level 5 4L65E, PI Vig 2600, HP Tuners with 2-Bar SD OS (Plus some smaller mods)
Support our Troops
Some of our cars come with high low octane tables stockOriginally Posted by foff667
Hey Al, if ya come over and show me how it works I'll let ya use it as much as you want
That's the problem.....I don't know how it works because it's not available on my truck...
Support our Troops
Originally Posted by Onyx Dragon
but with the default OS config, when you go into SD, it forces you to use low octane tables only, whereas the custom OS allows the PCM to continue to use both high and low for safety
Mike Horist
00 WS6 (TA) | 04 WS6 (GTP Comp G)
Mike \\#at&\\ horist \\&dot$\\com
BOTH cars HP Tuners Tuned
ill beta test it.
99 silverado 1500 5.3, 30 over, all new ported, polished, and milled heads 30 thou, 220 226 custom BEI cam. 2" intake valves, ported & polished TB, Long tube ceramic coated headers, magna flow cats, y pipe, 3" magnaflow, vera ram air intake, I6 TB stall, All new Drivetrain, 3 Trans coolers, Auburn E-Locker, 4.56 gears, Throttle body bypass, Flex-a-Lite E-Fans, LS1 e-fan harness, ASP Under Drive Pullleys, HP Tuner Pro. 1 Bar MAP SD OS upgrade. Amsoil EA Bypass Oil Filtration system.
So uh, is this out yet on 2.24.75?
Was this ever dev'd and enabled for the E40?
2006 CGM A4
HPT hase never hade a version that tune`s for you.
What ever happened with this. I have the VCM Scanner 2.24. It doesn't seem to have the RTT function available.
