beta testing wil be within a month or less done?Originally Posted by foff667
beta testing will begin soon and theres no set timeframe to have it done...when all the bugs are worked out so that you guys run into as few issues as possible with it thats when it will be released...for now use the copy-paste special feature...it too works just fine
Some of us are lazy (just kidding)Originally Posted by foff667
Is there going to be RTT for 2005 on 5.7 VZ Holden, I can RTT up to 2004 VY Holden but that's it. Pretty keen on this as I own a 2005 and I'm putting a blower on tomorrow, would make tuning it easier.
I've just tuned a blown 402 2004 VY Holden with RTT, This is my first big forced induction engine and it was easy.
LS2 Alloy Block 402 - VORTECH V7 Gilmer driven 15 psi 937.3 rwhp street driven.
I also have a 11/2005 VZ 5.7 Holden SSZ Ute, I have RTT working on mine with 1bar SD custom OS. I needed to update to Version 2.14 to get it to work.Originally Posted by NOS500
Cheers
Jamie
VZ SSZ UTE LS1 A4, COMP CAM & SPRINGS
foff667... you stated "i personally use the 1 bar SD RTT OS on every car i tune now." If I were to get the 1 bar SD RTT OS and tuned my car in SD, can I then (if I chose) copy those tables to my original MAF tune and run with the MAF? I still have not determined that I will run SD all the time but the option would be nice.
2013 Jeep Wrangler JK
3.6 V6
More MODs than Stock
2018 Ram rebel
5.7 Hemi V8
Stock
yup and because its one of our SD OS's it removes any secondary VE tables you may have & then adds an 'Alpha-N' TPS multiplyer table, RTT obviously for things like idle, pe,spark,etc...and if you decide on running SD full time you'll have full use of both the high/low octane tablesOriginally Posted by arthansen
Damn this really sounds helpful
Will this use the commanded AFR table? I mean, will the commanded AFR table be adjustable, and the scanner will adjust the VE table according to the AFRs that I have entered?
When you are doing a percentage of error, yes, it references what is being commanded.Originally Posted by GiveMeClams
PE Table and BE Table (if applicable) are adjustable through RTT, so I would image they would be available through the closed loop tuning.Originally Posted by GiveMeClams
Let me chew up my question, and spit it out in a little different shape: Will you be able to open the commanded afr table, enter the values that you want the engine to run at, and have the vehicle adjust itself to match the table?
simple answer is yes. Long answer is you can do that now, you just need to use our copy-paste featureOriginally Posted by GiveMeClams
I have been reading and some people have rtt. I looked in the help section and found the info there, but don't see it in the scanner. Is it only avaliable in the osesd?
86 Fiero Convertible 3800sc/4T65E HD(2002)
The RTT icon will appear in the scaner when you are scaning a car with the custom operating system installed and active . The scaner would need to check which group of tables is active to display them .Originally Posted by tweeder
link to help file
Thats whatI was wondering. I guess its time to order an upgrade
Do ya'll need any extra beta testers?
lol ya im free and quite hardcore plus have the 2.1.15
2006 SS Cobalt SC
Stage 2 ZZP Cams
Headers, 3.0" Full ZZP Exhaust
60lb inj. Intake.
2.8 Pulley
72# Lb. Supertech Springs
LNF Ext Valves and lashers
Cobre H/E, option B.
Torque Damper
HPTuned.
Bitchin'.
I'll beta test the LS2 GTO A4.
www.outlawpontiacdragseries.com
Come race with us in MA, PA, and VA!
2005 GTO A4 - Spintech X-pipe with Powerstick mufflers, IAT relocate, Volant, !scoops, !cowlgasket, !skid plate, LM-1, HPT2.0/MPVI Pro USB, 275x40x17 Nitto DR, rolled fenders, Pedders 2985 springs, Britax baby seat with 5 point harness.
Stock:13.36@104
Mods in sig:[email protected]
How's the beta testing going? Or is it?
