Results 1 to 7 of 7
Thread: E85 spark table
    Mar 2021
    41
    E85 spark table
    Truck is a 4.8 turbo, fueling is close to dialed in. No knock at all, running 24psi. How does the table look? I know i can add a couple degrees at wot but wondering if there should be more in cruising areas or just more in general. Trying to pick up a little acceleration when coming into boost.
    Jan 2011
    49
    Looks fine to me w/o knowing the compression. Put it on the dyno
    Jan 2014
    Australia
    1,996
    u will most likely not see knock on ethanol until ur way past peak torque/hp, best to adjust timing on a dyno so u can see actual gains/losses
    Advanced Tuner 4wheelinls1's Avatar
    Jun 2009
    Melbourne Australia
    284
    LS generally won't make power over 28 degrees WOT. Cruise up to 55 degrees with a cam. The Bi-directional control in the scanner is great for finding optimal timing in different load and rpm areas when on the dyno.
    Looks a little backwards from what I typically see them like. I typically pull a little timing around peak torque and then feed it back in as rpm increases. You have peak timing around peak torque and then pull it as rpm increases. While you may not be seeing knock, it's likely not making anymore power like that.
    Owner/Tuner@Evolution Automotive Performance
    Lincoln, Ne
    Aug 2009
    Calibrating
    3,378
    Peak tq usually highest cylinder pressure so requires usually little more fuel and less timing
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Jun 2009
    Melbourne Australia
    284
    Quote Originally Posted by Ben Charles View Post
    /\ /\ /\ yes. And with increasing RPM have increasing timing past peak torque.
