Results 1 to 13 of 13
Thread: Tuning 2008 Tahoe for new headers and intake
    Dec 2021
    7
    I had the motor in my Tahoe rebuilt w/DOD delete and a BTR stage 2 truck cam. It was tuned after that but I added 1 7/8 headers and a cold air intake and would like to clean up the tune. I've watched various videos on youtube and I'm familiar with tuning carburetors, but never messed with this before. I installed a wideband o2 sensor this morning and wondering where to start. Where do you start your tuning and when do you know you're done?
    Tune and first drive are attached. Thanks for any insight you can provide. start1.9.2022.hptDrive 1 1.9.2022.hpl
    Aug 2009
    Calibrating
    3,377
    I do remote tuning if interested learning too
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Dec 2021
    7
    I would not be shocked if I end up there. Thank you.
    Jun 2020
    33
    Start by setting up your histograms in the scanner to match the areas you need to adjust in your tune, watch some vids on this. Set up wideband % error histogram. Take some timing out of the low octane table and log for knock. Then start scanning your drives.
    Dec 2021
    7
    Quote Originally Posted by crew chief View Post
    Well, I did this, watching a youtube from Goat Rope Garage and the EQ seemed to be reading well. Couple of questions:
    1. I went in to disable Dynamic Airflow and it was already disabled. High RPM Disable was 100 and Re-enable was 0. Is that correct?
    2. I drove to work and then copied and pasted by half to the airflow/frequency table. Very minor differences but it seemed like it ran better (less rich) than before. Didn't make sense to me.
    Mar 2011
    Ripley, MS
    1,865
    Quote Originally Posted by KSJeff View Post
    1. I went in to disable Dynamic Airflow and it was already disabled. High RPM Disable was 100 and Re-enable was 0. Is that correct? That's correct. That means it's disabled.
    It looks like the changes to the MAF table are pretty minor. That's what I would expect with a combo light yours.
    Dec 2021
    7
    Been tuning my MAF table and it ends up flattening out on the high frequencies. Is this normal?
    Mar 2011
    Ripley, MS
    1,865
    That looks very close to stock.
    Dec 2021
    7
    I'm assuming a stage 2 truck cam, headers and cold air intake isn't too far from stock except for the DOD delete. Or would you expect a BTR Stage 2 truck cam to look different than that? So, no issues with the flattening out?
    Mar 2011
    Ripley, MS
    1,865
    I would not expect the MAF curve to change very much from the original curve in your application.
    For reference, here's a stock 2008 Tahoe MAF curve.
    Dec 2021
    7
    Thank you. I'm going to keep dialing in the MAF then I'll move on. Appreciate it.
    Dec 2021
    7
    So, I have the MAF dialed in and getting ready to put the final tune for MAF in it before I start on speed density. For whatever reason, dynamic airflow was disabled when I started. High RPM Disable was 100 and Re-enable was 0. Should I put it back to stock or is there some reason it was left disabled after my camshaft installation and DOD delete?
    Jan 2019
    9
    Sounds like the guy who tuned it for the DOD delete and cam install did a MAF only tune. I'd wager that your VVE tables are still stock.
