Results 1 to 8 of 8
Thread: dynamic airlfow manifold volume
    Aug 2021
    842
    so i just figured out my Dynamic airflow is set for stock intake manifold volume. if i update this for my MSD intake, would i need to re-tune my MAF?
    Jun 2014
    Boulder, CO
    202
    Changing the intake manifold volume value shouldn't have an effect on MAF calibration. I believe that the manifold volume affects transient fueling more than anything else.
    Aug 2021
    842
    ok thank you!
    Jan 2014
    Australia
    1,982
    any change in intake/manifold will need maf/vve to be checked and corrected
    Aug 2021
    842
    noted. thank you!
    Advanced Tuner 4wheelinls1's Avatar
    Jun 2009
    Melbourne Australia
    284
    The VVE will be impacted the MAF should not, a MAF curve ideally is based on a bench measurement, if the VVE and other aspects, manifold volume, cylinder displacement are correct then the MAF "In theory" should not alter, it is an air measurement device. Where it alters is where the intake is modified impacting the flow through the MAF such the stock calibration is altered.
    Advanced Tuner ttz06vette's Avatar
    Sep 2008
    Charlotte, NC.
    242
    Quote Originally Posted by 4wheelinls1 View Post
    This is what I found as well. Had to adjust VVE after I increased volume but MAF was within 2%.
    Aug 2021
    842
    nice. thank you 4wheelinls1 & ttz06vette for the insight.
