Results 1 to 9 of 9
Thread: 2014 Ram Whipple 2.9L ETC Errors Help.
    May 2017
    Jackson, TN
    31
    2014 RAM 1500 5.7L
    Just installed a Whipple 2.9L kit and cannot get it dyno tuned do to ETC service error over 3/4 throttle. Base tune has been established with updated injector data and it idles and drives fine up to 3/4 thrrotle. One you go wide open service ETC flashes on dash and goes into limp mode. Simply pull over turn off and turn truck back on and it will drive fine again.
    Has a barometric too low code but believe that is a diagnostic code voltage update to fix that from research here.
    Sometime on start it gets the ETC service code, but again just restart and it goes away.
    Any idea on what to look for. Tried replacing and relearn on throttle body but it didn't fix it.
    Any help greatly appreciated cannot finish getting the truck tuned till the issue is resolved.
    Advanced Tuner coanan's Avatar
    Mar 2009
    S. Florida
    582
    Quote Originally Posted by JayRab View Post
    2014 RAM 1500 5.7L
    You should post the tune for better help.
    2018 Trackhawk PCM/TCM tune by Dusterhoff.
    Flex Fuel, MMX faux 95mm TB, GripTec 2.85, 10% ATI lower, FIC1200, ARH 1 7/8 w/cats, 180 T-stat
    13 Chrysler 300S, RAM BGE 412 stroker, cam motion 232/246 619/619 118 +4, ATI 18% OD pulley
    Whipple Gen5 3.0, 2.50 upper pulley, Smooth Boost controller, FIC 1200 inj. Nick W 108mm TB, FORE dual return fuel system, E85, FTI 2800 stall(SRT83380), SHR WAR Viking trans and valve body, Getrag 3.73, 1 7/8 kooks w/hi-flow cats, 3" Magnaflow Cat-back 943rwhp
    May 2017
    Jackson, TN
    31
    les12922.hpt
    Attaching current tune
    Mar 2009
    S. Florida
    582
    les12922.hpt
    Ever try enabling sensed MAP and see what happens?
    In eng diag raise torque delta/fault to 966 across the board
    In eng diag airflow raise MAP delta hi/low to 250 BORO voltage min to 0.05
    Just some things to try
    Advanced Tuner f.creek-ranch's Avatar
    May 2018
    Germany
    589
    eng diag p2172/2174 to 250 kpa
    Baro voltage 0,xx
    The Map should be correct. Check the o ring from map and watch out for leaks.
    Nov 2009
    All Around
    3,149
    key on engine off log
    try this
    les12922 FIX.hpt
    Jul 2015
    925
    Are you using the stock throttle body?
    Mar 2009
    S. Florida
    582
    Too bad a lot of people never come back to report success or failure from help they seek.
    Would help others that do a search with similar problems.
    May 2017
    Jackson, TN
    31
    The truck is still using stock throttle body.
    The vehicle has been dropped off at the tuner again maybe he can get it running. I will share the tips you guys gave with him as well to see if that will solve the issues.
