Results 1 to 3 of 3
Thread: Connecting prolink to AEM Wideband
    Feb 2022
    2
    When connecting my AEM wideband to the Pro Link should I connect the analog and canbus connections?
    13,565
    You'd only use the can-bus connector if the vehicle was using can-bus. Otherwise that part of the wideband wouldn't work if it was an older non can-bus vehicle.
    The analog doesn't get used if can-bus.
    Dec 2005
    604
    I use the CAN bus inputs on the ProLink with the 30-0300. It has better range than the analog signals.
    If you have the 30-0334, that one connects directly to the OBD2 port. And, only works with CAN based vehicles.
